Axle problems......AAAHHHHHHHRRRRRRHHHH!!!!!!!
Old Jul 19, 2003 | 11:23 PM
Racer613's Avatar
Default Axle problems......AAAHHHHHHHRRRRRRHHHH!!!!!!!
Ok...get this ....Place Racing mount kit and weld in housings for Crx/H22...new custom crossmember....h22a(93) the damn thing fires up great, very strong sounding....
I drove the beast down the driveway at idle speed..700 rpm...I put the gas on about 1000 rpm, cornered a curve at 700 rpm....driver's side axle came apart from the housing and the shaft...the cv boot was shredded!!!!!!!! Not broken..jus came apart. Turns out the custom h22/Crx axle was 1/2" too short and the shaft and bearings just popped out
What the hell!!! Did Place Racing send me the wrong axles? I tried an B series axle with the h22 attatchment..but was too long by 1"......what axle can I use until I can send the Place Racing axle back for a replacement....it has got to be an Integra axle...but what year is the right length?????????
Modified by Racer613 at 9:22 AM 7/21/2003
Old Jul 20, 2003 | 05:09 AM
Turbogixxer's Avatar
Default Re: Axle problems......AAAHHHHHHHRRRRRRHHHH!!!!!!! (Racer613)
I would try 1st gen integra axles. They are the shortest of all. They get longer as the gens get higher.
Old Jul 20, 2003 | 07:59 AM
Racer613's Avatar
I thought that same thing...maybe a 86-89 Teggy? Place Racing better help me out with some 200whp+ 1st gen teggy axles then...
Old Jul 20, 2003 | 06:58 PM
Racer613's Avatar
The Crx/H22 Raging Demon is complete!!!!!!!!! I used custom 96 Integra axles........the damn thing is f-ing fast!!!!!!!!!! It pulls hard as all hell in 5th gear!!!!!!!!!!!!!!!!
Old Jul 20, 2003 | 07:05 PM
poison's Avatar
Default Re: (Racer613)
wtf? 96 integra axles went right in huh??
What midshaft you using? that's insane.
Glad to hear it's runnin great bro!
Old Jul 20, 2003 | 08:29 PM
Racer613's Avatar
My bad Poison.......they were 86 Teggy axles..I dont know why I typed 96...too much cronic.
Old Jul 20, 2003 | 08:38 PM
poison's Avatar
Ohh ok. lol. You had me fooled.
Old Jul 21, 2003 | 12:00 AM
Default Re: (poison)
What is "custom" about them?
Old Jul 21, 2003 | 12:24 AM
Racer613's Avatar
had to take off the c/v boot....and remove the Integra sized threading on the end(?)...and replace it with the h22 sized housing. The Teggy ones dont fit.
Old Jul 21, 2003 | 08:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Ohh ok. lol. You had me fooled.</TD></TR></TABLE>
Me too
Old Jul 21, 2003 | 09:39 AM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racer613 &raquo;</TD></TR><TR><TD CLASS="quote">had to take off the c/v boot....and remove the Integra sized threading on the end(?)...and replace it with the h22 sized housing. The Teggy ones dont fit.</TD></TR></TABLE>
Are you talking about swapping Prelude joints onto the Integra axles? If so, then they're the same size... just longer input shaft on the Prelude joints and deeper cup for the axle to move in. Since we have an abundant amount of Prelude axles, we've been lately taking off the joints and using them on customer's cars with either 89 Integra axles or 90 Integra axles (depending on which is needed for their car) and it works out perfectly.
On an EF, we took measurements and it's very similar to an EG chassis (hub to hub distance) and the way the H22 is positioned in there, you should be able to use 90 Integra axles on both sides..... but that depends on what mount kit that you're using and how it's positioned in your car.
Old Jul 21, 2003 | 06:24 PM
Racer613's Avatar
yeah...I am using the Place Racing weld in kit..and mounts. The 86 teggy's axles were perfect length....all I need to do now is find a place that makes 300whp+ axles for the track. Or I can buy a **** load of stock 86-89 Teggy axles from AutoZone for 125 without core.....
Old Jul 21, 2003 | 08:36 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racer613 &raquo;</TD></TR><TR><TD CLASS="quote">yeah...I am using the Place Racing weld in kit..and mounts. The 86 teggy's axles were perfect length....all I need to do now is find a place that makes 300whp+ axles for the track. Or I can buy a **** load of stock 86-89 Teggy axles from AutoZone for 125 without core.....</TD></TR></TABLE>
LOL, with a 10 minute axle repair kit before you line up for the next run
Old Jul 21, 2003 | 10:13 PM
Racer613's Avatar
thats what I am thinking of doing if I cant find the 300+ whp 86-89 Teggy axles...
I better buy 3 sets of each.....damn car pulls like a beast!!!!!!!!!!
hardcore97
Transmission & Drivetrain
Dec 6, 2012 01:11 PM
h22sedan
Aug 6, 2010 02:54 PM
killsnake562
Oct 9, 2008 10:19 PM
Daily Interlude
Mar 17, 2006 05:49 AM
90Hatch
12
Jun 18, 2003 01:48 AM
