what is hone? what does it do?
Old Jul 19, 2003 | 07:58 PM
wm5holla's Avatar
Default what is hone? what does it do?
can you guys tell me about it. i when to this rent tool shops and i saw they rent a tool where u can hone ur walls.. . i really have no clue what it does. can u drop some knowlege on me!
Old Jul 19, 2003 | 08:03 PM
slomofo's Avatar
GDD Member
Default Re: what is hone? what does it do? (wm5holla)
Hone, bore, same thing. Enlarging your cylinder walls by making them wider. Your cylinder is a round circle with a piston in it, you can make the hole wider by honing, you do this to increase displacement, but you need wider pistons to go in the wider cylinders.
Old Jul 19, 2003 | 08:11 PM
Goldfingiz's Avatar
Default Re: what is hone? what does it do? (slomofo)
Or if god forbid you blow your motor and scar your cylinder wall, usually you need to hone it before rebuilding.
Old Jul 19, 2003 | 08:50 PM
Fkned's Avatar
boring and honing are not the same.you hone a block either after u overbore or to freshen-up the motor.honing is using a machine with stones attached that go up and down in the cyl.it puts a cross-hatch on the walls that help retain oil for the rings and pistons.boring the block is making the cyl.s bigger for oversize pistons.if you dont hone after boring the rings will not seat.
Old Jul 19, 2003 | 08:59 PM
NonovUrbizniz's Avatar
Loved
honing is the proces where you leave cross-hatched roughed-up surface on the walls of the cylinder... this is mainly done to seat the rings... it gives them an even smooth but rough enough surface to seat properly...
It's also done when putting the same rings back in... it allows the honed areas to either stay the same or be worn off to seat the walls so to speak...
qazaq
Jul 14, 2007 04:20 PM
Rosko
12
Mar 17, 2007 04:09 PM
TurboSC
Jul 23, 2005 08:44 AM
AgentJam
Jul 22, 2004 06:22 PM
deSigi
Jun 8, 2004 06:50 PM
