Cable and Hydrolic clutches, interchangeable?
Old Jul 19, 2003 | 05:26 PM
Goldfingiz's Avatar
Default Cable and Hydrolic clutches, interchangeable?
Hey guys, a friend has a Del Sol witha hydro tranny, and I have a 91 CRX Si. Both B series. We want to trade clutches. To my understanding this is possible. Is it true?
Old Jul 19, 2003 | 07:48 PM
slomofo's Avatar
GDD Member
Default Re: Cable and Hydrolic clutches, interchangeable? (Goldfingiz)
Yes, it can be done.
Old Jul 19, 2003 | 07:53 PM
Goldfingiz's Avatar
Default Re: Cable and Hydrolic clutches, interchangeable? (slomofo)
Old Jul 19, 2003 | 09:19 PM
salbaje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goldfingiz &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, a friend has a Del Sol witha hydro tranny, and I have a 91 CRX Si. Both B series. We want to trade clutches. To my understanding this is possible. Is it true?</TD></TR></TABLE>
do you have a b16 in your ride?? You meant both are D series??
Old Jul 19, 2003 | 11:31 PM
Goldfingiz's Avatar
Default Re: Cable and Hydrolic clutches, interchangeable? (salbaje)
We just want to switch clutch, not trannys. I have a B20.
Old Jul 20, 2003 | 01:24 AM
letholone's Avatar
Default Re: Cable and Hydrolic clutches, interchangeable? (ek9t)
thats not 100 percent true.
92-93 LS cable trannys are big spline. as with all hydro trannys.
JDM cable trannys are the same way. if you got one from a EF then its going to be small splined.
if it came from an XSI(integra) in the 92-93 years. it will be large spline.
Old Jul 20, 2003 | 06:02 PM
Goldfingiz's Avatar
Default Re: Cable and Hydrolic clutches, interchangeable? (letholone)
I have a YS1. Pretty sure that's a 92-93 GSR tranny but 90-91 LS's were also stamped YS1 if I'm not mistaken. My 92 GSR has a YS1 as well...
Old Jul 20, 2003 | 06:16 PM
Audi RS4's Avatar
Lover
yes
Old Jul 20, 2003 | 07:33 PM
sleeper4dr's Avatar
all 92+ b-series trannies can swap clutches because, as it was said, they have larger splines on the counter shaft.
all JDM S1/J1/Y1 trannies HAVE to use the 90-91 integra clutch disks because the trannies have smaller splines on the counter shaft.
90-91 b-series trannies were labeled A1/S1 and i think J1.
92-93 GSR and LS trannies were BOTH labeled YS1.
and to answer the original question, you can only swap clutches if the CRX has a YS1 tranny.
hth, Jason
BeezInACan
Transmission & Drivetrain
Nov 27, 2008 07:15 PM
shadhman
May 20, 2008 09:21 PM
snowseeker
May 3, 2005 05:38 PM
g2lsv
Nov 22, 2004 10:52 AM
99AccordCF8
Mar 27, 2004 12:29 PM
