have a problem with rebuild not starting...got spark, fuel, timing is on?
Old Jul 19, 2003 | 03:43 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default have a problem with rebuild not starting...got spark, fuel, timing is on?
put new rings, pistons, and rod bearings in a gsr with a slight hone on the cylinders. used assembly lube. plastigauged the bearings. the clearance was .002. is that clearance too little? someone told me that .002-.003" is ok. the motor was turning ok by hand, but it is not that easy to turn and this is with the spark plugs out. is the clearance my problem and is that why the motor is not starting??? because it should be able to spin? thanks.
Old Jul 19, 2003 | 05:40 PM
X2BOARD's Avatar
Default Re: have a problem with rebuild not starting...got spark, fuel, timing is on? (not so civic)
First... you're building a motor using info that someone TOLD you ???
BTW, .002" is the Service Limit on a B series motor for rod bearing oil clearances. (but I didn't tell you that...heh heh heh)
Second... (Have to ask): Have you used the plastigauge process before ? Do you know how to do it properly ? (not to hard anyways). Did you check for tapering in the rod and main journals before you did the final assembly ?
**Assembly should crank relatively smoothly by hand.
Third: When doing a fresh rebuild, you need to prime the fuel and oil pumps considerably (All of your passages and lines will be EMPTY.) before starting and did you ensure that the cam timing (t/belt) is dead on ? (1 notch off and it won't start... or will start and die right after.
Old Jul 19, 2003 | 05:51 PM
orange.honda's Avatar
Default Re: have a problem with rebuild not starting...got spark, fuel, timing is on? (X2BOARD)
also how is compression? that is also essental.
Old Jul 19, 2003 | 06:06 PM
TeStUdO's Avatar
Default Re: have a problem with rebuild not starting...got spark, fuel, timing is on? (orange.honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orange.honda &raquo;</TD></TR><TR><TD CLASS="quote">also how is compression? that is also essental.</TD></TR></TABLE>
yeah but your numbers wont be high till you actually get it started and seat the rings
Old Jul 20, 2003 | 07:20 PM
found the problem. there was no compression building. everything was ready to go and my friend who's gsr this is, tightened the distributor on with the slot on the cam the wrong way...ouch!!! i wasn't aware of this and saw the distributor wiggling!!! so i cam timing was off, the cam was surely binding almost locked up. since we tried starting the car, unaware, the valves probably got bent. gotta pull the head soon.
Old Jul 20, 2003 | 10:36 PM
Ryan C's Avatar
you couldnt tell the valves were hitting the pistons
Old Oct 5, 2003 | 01:26 AM
baruba's Avatar
soo any updates?
Old Oct 5, 2003 | 08:15 AM
Default Re: have a problem with rebuild not starting...got spark, fuel, timing is on? (baruba)
this was an oldie post but the valves had to be adjusted that's all.
Old Oct 5, 2003 | 04:00 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic &raquo;</TD></TR><TR><TD CLASS="quote">this was an oldie post but the valves had to be adjusted that's all.</TD></TR></TABLE>
none were bent?
Old Oct 5, 2003 | 06:34 PM
Default Re: have a problem with rebuild not starting...got spark, fuel, timing is on? (TeStUdO)
no surprisingly
94GSRMR
Jan 1, 2011 07:05 PM
rich7777
Aug 5, 2010 08:49 AM
integrawow
15
May 5, 2009 04:16 AM
lint_rides_again
Mar 27, 2008 08:14 PM
Ti3d in
Apr 8, 2007 10:09 PM
