d16z6 head on my d15b1 possible?
Old Jul 19, 2003 | 01:10 PM
pinoyboy204's Avatar
Default d16z6 head on my d15b1 possible?
as the topic says. i have access to a z6 head, i just don't know if it is ok or not to to swap the head or should i just go with the b2 bottom first, then do the mpfi swap...etc..
Old Jul 19, 2003 | 01:19 PM
Malgerus's Avatar
Default Re: d16z6 head on my d15b1 possible? (pinoyboy204)
Start with the MPFI swap first, then as you get more knowledge move up to the mini me. It'll cost more but you'll learn more.
Old Jul 19, 2003 | 07:12 PM
Default Re: d16z6 head on my d15b1 possible? (Mr. S)
should i start off with the b2 block instead of the b1? if i take the b2 block, theres going to be a lot of work///
Old Jul 19, 2003 | 07:55 PM
Redline130's Avatar
Why will you have more work with the B2 block than the B1? I agree with Mr.S, start with the MPFI conversion first, it will get most of the wiring work out of the way.
Old Jul 19, 2003 | 09:27 PM
Default Re: d16z6 head on my d15b1 possible? (Redline130)
yea, i think i should start with that...
another thought, the b1 block is more slower than the b2 block..
is it still worth putting the mpfi conversion on the b1 and then the z6 head or try and find a b2 block then go with the mpfi conversion then the z6 head???
EDIT: b1 block rated at 72 HP, while the b2 block is rated at 92 HP
Old Jul 19, 2003 | 10:03 PM
Louie B.'s Avatar
b1 and b2 bottom ends are pretty much the same... the hp diferences are made in the ECU / I.M.
Old Jul 19, 2003 | 10:04 PM
USDM 4G VTEC's Avatar
B1 and B2 blocks are basically the same thing
u will get the same power output by putting the Z 6 head.....
do MPFI conversion and then do mini me
do a search for both
theres tonssssss of info here
Old Jul 20, 2003 | 01:33 AM
Broken Gearbox's Avatar
Default Re: d16z6 head on my d15b1 possible? (USDM 4G VTEC)
the blocks are both the same. but think about doing the MPFI swap first then put the VTEC head. also does anyone know if D15/D16 head bolts the same?
Old Jul 20, 2003 | 06:51 AM
Default Re: d16z6 head on my d15b1 possible? (James.)
i'm pretty sure they bolt the same. someone back me up on this...
Old Jul 20, 2003 | 09:44 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James. &raquo;</TD></TR><TR><TD CLASS="quote"> also does anyone know if D15/D16 head bolts the same?</TD></TR></TABLE>
The bolts are different lengths... I've seen in previous posts where people have had problems with too long / short of bolts when doing a mini-me. Can't remember which ones you need to use, I would guess the Z6 bolts, but someone please confirm this.
91grape
Jun 27, 2012 06:01 PM
spens 91 Ef
Jan 2, 2009 11:04 PM
ex_ricer
Dec 14, 2007 08:54 PM
driftkid01
Apr 3, 2004 06:15 PM
SLOAZZ95
13
Aug 21, 2003 09:13 AM
