Where is the idle adjustment screw?
Old Jul 19, 2003 | 09:58 AM
B2FiNiTY's Avatar
Default Where is the idle adjustment screw?
Anyone have a pic of it on a 88 crx si? I can't seem to find one. I know it is on the tb but where?
Old Jul 19, 2003 | 10:06 AM
Malgerus's Avatar
Default Re: Where is the idle adjustment screw? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have a pic of it on a 88 crx si? I can't seem to find one. I know it is on the tb but where?</TD></TR></TABLE>
Right on the top of the throttle body. Might have a little green cap on it.
Old Jul 19, 2003 | 11:20 AM
B2FiNiTY's Avatar
Default Re: Where is the idle adjustment screw? (Mr. S)
What kind of screw is it? Philip's head? There is something that resembles it but it just looks flat with no place for a screw driver.
Old Jul 19, 2003 | 11:27 AM
MrTodd's Avatar
It's a flat screw driver type, not philips. The screw is most likely covered with hondabond or something similar, so it can be hard to see sometimes.
Check out this pic...
This picture is off a '92 Civic EX, but the location is the same. #1 on the diagram is the TB idle adjustment screw.
Old Jul 19, 2003 | 11:35 AM
B2FiNiTY's Avatar
Default Re: Where is the idle adjustment screw? (MrTodd)
Why does hondabond need to be there? Will it leak something?
Old Jul 19, 2003 | 11:44 AM
etp72's Avatar
what is the idle speed supposed to be on the 88 CRX Si?
Modified by etp72 at 6:10 AM 7/20/2003
Old Jul 19, 2003 | 11:55 AM
B2FiNiTY's Avatar
Default Re: (etp72)
At least 800 when warm.
Mine is too low and the whole car shakes. At least it doesn't stall though.
Old Jul 19, 2003 | 12:04 PM
crashtest Sonny's Avatar
sorry to jack your post..where is the IAT sensor on that picture?
Old Jul 19, 2003 | 12:20 PM
MrTodd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Why does hondabond need to be there? Will it leak something? </TD></TR></TABLE>
Mechanics are supposed to put hondabond, or silicone gasket maker coated on top of the screw, just so it doesn't loosen while the car is running. It's not a big deal at all, I don't have any gunk on my idle screw.
As for the IAT sensor placement, the picture doesn't show the actual sensor, but you can see where it plugs into the I/M. Look at hose #24, where it plugs into the manifold, the IAT sensor is located just to the right of the hose. You can see where it plugs in on the picture....
Old Jul 19, 2003 | 01:20 PM
Malgerus's Avatar
Idle should be 750+-50 rpm, not 800. That's too high.
Old Jul 19, 2003 | 02:54 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Idle should be 750+-50 rpm, not 800. That's too high.</TD></TR></TABLE>
Uh 750 + or - 50 is 700-800, so 800 is fine. It just should be in that range.
Old Jul 19, 2003 | 03:20 PM
Malgerus's Avatar
Default Re: Where is the idle adjustment screw? (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">
Uh 750 + or - 50 is 700-800, so 800 is fine. It just should be in that range.</TD></TR></TABLE>
Ok, I'm officially an idiot
Old Jul 20, 2003 | 12:12 AM
DB2-R81's Avatar
25 Year Member
#1 is the idle air mixture adjustment screw; the idle speed adjustment screw is near the cable linkage pulley and is not shown in that diagram. Mess with #1 and you are changing the air, fuel ratio at idle. Yes, it will change your idle speed but only by allowing more or less air to bypass the throttle plate in the TB at idle.
When the #1 screw is turned inwards the engine will be running richer at idle. If you have environmental testing in your location at idle, your hydrocarbon reading may be above a passing level. The idle speed adjustment screw can be found above the red arrows in this picture, change its setting and you will only change the idle speed not the air fuel ratio.
Modified by DB1-R81 at 1:44 AM 7/20/2003
Old Jul 20, 2003 | 04:11 PM
B2FiNiTY's Avatar
Default Re: Where is the idle adjustment screw? (DB1-R81)
I poked around and couldn't find it. I will take some pics and maybe someone can point it out for me. Thanks.
Old Jul 21, 2003 | 11:48 PM
B2FiNiTY's Avatar
Here's a pic from up top.
Old Jul 22, 2003 | 03:11 PM
matt j's Avatar
that isnt where its at look farther back ON the throttle body itself
Old Jul 22, 2003 | 03:18 PM
halfpint's Avatar
DB1-R81, the idle speed screw your referring to, isn't that the throttle stop screw which the factory manual says should not be changed?
Old Jul 22, 2003 | 03:28 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Where is the idle adjustment screw? (halfpint)
Dude, it's this one.
The one inside the red parenthesis.
BTW, if you like your T/B to look like that AND be 4 mm bigger in bore, email or PM me.
Old Jul 22, 2003 | 06:41 PM
B2FiNiTY's Avatar
Default Re: Where is the idle adjustment screw? (Spaceballs the lunch box)
AhH! I will go check right now. Thanks.
2002civicrider
Honda Civic (2001 - 2005)
17
Jun 25, 2018 06:38 PM
RDAYA0
16
May 1, 2008 10:25 PM
Steezn4NOReason
Dec 4, 2004 09:02 PM
Myh4tch
Jul 28, 2004 04:06 PM
Glocked1
Oct 3, 2003 05:13 AM
