That A/C line that gets a hole rubed in it from CAI's...which ones will fit?
Old Jul 19, 2003 | 05:04 AM
JDubya's Avatar
Default That A/C line that gets a hole rubed in it from CAI's...which ones will fit?
My intake rubbed into my A/C line and i can't tell if it made a hole or not but my A/C doesn't blow cold anymore so i'm guessing it did. I've got a '98 GS, what other Teg's A/C line will fit? like other year LS's, GSRs, etc...
Old Jul 19, 2003 | 09:17 AM
vladd's Avatar
Default Re: That A/C line that gets a hole rubed in it from CAI's...which ones will fit? (ALL MOTOR LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote">My intake rubbed into my A/C line and i can't tell if it made a hole or not but my A/C doesn't blow cold anymore so i'm guessing it did. I've got a '98 GS, what other Teg's A/C line will fit? like other year LS's, GSRs, etc...</TD></TR></TABLE>
pretty sure they're all the same. my friend swapped ac from a 98 gs into a 94 rs and everything fit perfectly.
Old Jul 19, 2003 | 10:07 AM
MooreBoost's Avatar
Default Re: That A/C line that gets a hole rubed in it from CAI's...which ones will fit? (civicdxtyper)
Mine did the same, except I cought it before it went through. Just be sure to double wrap your as line and put alittle insulation on the CAI where it rubbed. I also think that the AC lines are all the same.
gmoore
Old Jul 19, 2003 | 12:02 PM
confucius's Avatar
Default Re: That A/C line that gets a hole rubed in it from CAI's...which ones will fit? (tegunderpressure)
thats what u get for getting AEM.
overpriced piece of shlt.
Old Jul 20, 2003 | 10:16 AM
JDubya's Avatar
Default Re: That A/C line that gets a hole rubed in it from CAI's...which ones will fit? (confucius)
FYI, i didn't have AEM, i just had a generic 2.5" CAI. Now i've got a DIY Icebox.
Old Jul 20, 2003 | 12:31 PM
JDubya's Avatar
so the AC line from a GSR will fit non VTEC's?
Old Jul 20, 2003 | 01:02 PM
Russ713's Avatar
dAng!
you might see about getting the line welded back. I had an 1/8" hole rubbed into my line and got it welded shut for 20 bux.
Old Jul 20, 2003 | 02:18 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote">so the AC line from a GSR will fit non VTEC's?</TD></TR></TABLE>
yup
vladd's Avatar
Default Re: That A/C line that gets a hole rubed in it from CAI's...which ones will fit? (Russ713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russ713 &raquo;</TD></TR><TR><TD CLASS="quote">you might see about getting the line welded back. I had an 1/8" hole rubbed into my line and got it welded shut for 20 bux.</TD></TR></TABLE>
you could've just bought a new line at a junkyard for 5 bucks.
Old Jul 20, 2003 | 02:51 PM
onlyNls's Avatar
same thing happened to me. I took it to two different mechanics and they told me they couldn't order a new line for me or fix it, and that i have to take it to acura..sux oh well summer's almost over anyways. I might try the welding idea.
Old Jul 20, 2003 | 06:13 PM
Russ713's Avatar
dAng!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">
you could've just bought a new line at a junkyard for 5 bucks.</TD></TR></TABLE>
yeah, if only there were some junked del sol's in this area, I would've done that instead. Since there were none, I opted to repair the line so that I could have the AC up and operational. It's too hot and humid here to be without AC.
The-obd0-one
May 4, 2010 10:09 AM
catdaddy77
May 9, 2009 06:00 AM
JarvisW
Jun 30, 2007 05:38 PM
ILOVEGIRLS
Sep 16, 2002 02:08 PM
jthelman
Sep 11, 2002 01:49 AM
