Rear Disc pissing me off. grrrrr
Old Jul 18, 2003 | 04:39 PM
Audi RS4's Avatar
Lover
Default Rear Disc pissing me off. grrrrr
so let's say you start off in the morning to goto work and you pull out of the driveway and your car feels like you left the parking brake up, but it is completey released and that when you start to slow down at a light or stop sign you barely have to press the brakes because the rear brakes are already "grabbing"......wtf....i know the emergency brake is not up because the cables are not even connected .....anybody ever had this problem......personal expierences, opinions, comments are welcomed..........
Old Jul 18, 2003 | 05:04 PM
JaeOne3345's Avatar
Default Re: Rear Disc pissing me off. grrrrr (AK1200)
edit oops didnt read the linked title. Are the calipers old and in need of a rebuild? Have u checked the the part where the ebrake cable attaches to in the rear? perhaps a spring is binding.
Old Jul 18, 2003 | 05:13 PM
Audi RS4's Avatar
Lover
Default Re: Rear Disc pissing me off. grrrrr (JaeOne3345)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">edit oops didnt read the linked title. Are the calipers old and in need of a rebuild? Have u checked the the part where the ebrake cable attaches to in the rear? perhaps a spring is binding.</TD></TR></TABLE>
well that's one thing i was thinking, but how do tell if the calipers need rebuilt or even replaced? what goes bad with them? a seal, etc...... well the parking brake cables are not attached to the caliper at all.....
one more thing....can the prop valve have anything to do with this?
Modified by AK1200 at 6:42 PM 7/18/2003
Old Jul 18, 2003 | 07:14 PM
Mohudsolo's Avatar
A common problem is the pins the caliper slides on get full of crud and sieze up. Mine were rusted solid, inside pad worn out, outside pad nearly new. It could also be the caliper not adjusting properly with the e-brake not connected. Check the boots on the piston, if torn, it will not retract properly when off the brakes. Some pads fit too tightly in the carrier and need to have the backing plate ground slightly on the edges to slide properly in the carrier. Could also be a bad hose restricting fluid flow. The can separate internally and let pressure in but not out. Feel for soft spots and look for bulges or damaged cover.
Old Jul 19, 2003 | 07:05 AM
Audi RS4's Avatar
Lover
Default Re: Rear Disc pissing me off. grrrrr (Mohudsolo)
thanks
Old Jul 19, 2003 | 08:40 AM
kickerx's Avatar
that happened to me awhile back. either the e-brake cable is siezing up or you have a sticky caliper.
Old Jul 19, 2003 | 03:37 PM
Audi RS4's Avatar
Lover
Default Re: Rear Disc pissing me off. grrrrr (kickerx)
the ebrake cables are not even hooked up.........
Old Jul 19, 2003 | 06:14 PM
FerioVtec94's Avatar
its probably the slides in the calipers, i had this problem with one of my rear calipers, they only cost about 9 bucks a side for the slides....i would try that first
Old Jul 20, 2003 | 06:20 AM
Audi RS4's Avatar
Lover
Default Re: (FerioVtec94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioVtec94 &raquo;</TD></TR><TR><TD CLASS="quote">its probably the slides in the calipers, i had this problem with one of my rear calipers, they only cost about 9 bucks a side for the slides....i would try that first</TD></TR></TABLE>
do you have any information on where you bought them and how you did it?
LSVTEC 91 Civic
Honda Fit
37
Nov 15, 2007 05:52 AM
98GSRDC2
Mar 20, 2007 02:44 PM
Bond
Oct 2, 2005 02:05 PM
LAKER HATER
Sep 12, 2005 09:01 AM
