will not start
Old Jul 18, 2003 | 01:45 PM
KRAWMAN's Avatar
Default will not start update
i have now checked the reading on ecu. it is showing 16 flashes. i have released presure from tank by opening it. pulled fuel in line from tank and do not get fuel when key is in run position. i i understand the system fuel should flow with key in run position? car has aprox. 300k how can i further check for proper function ok the fuel system? is there a relay that may be bad that might be replaceable? i have also replaced the throttle body assmb. as a possible resolution with no results.
Modified by KRAWMAN at 6:40 AM 7/19/2003
Old Jul 18, 2003 | 02:14 PM
APEX CRX's Avatar
need more info, what did you mean by "no pressure in tank, have opened it?" cuz if you're getting gas to th tb then fuel fump is working. try checking main fuses and relays
Old Jul 18, 2003 | 07:45 PM
CRX Si's Avatar
Default Re: (APEX CRX)
check your timing, if you have fuel and spark it should start..
Old Jul 18, 2003 | 07:57 PM
FourthGenHatch's Avatar
Default Re:
You haven't given us enough info but possibly...
http://www.fourthgenhatch.com/mainrelay.html
biggs88
Sep 23, 2012 01:31 AM
teg racer 877
Apr 7, 2010 09:53 PM
ohfosho
19
May 8, 2008 09:17 AM
bengal
Aug 9, 2006 08:50 AM
torzy
May 9, 2006 02:14 AM
