Trunk release via alarm system
Has anyone ever installed an alarm system (Viper in particular) with the trunk release solenoid? Did you use the DEI piece or the OEM Honda?
Thanks for any info!
Be more specific, DEI trunk release or Honda trunk release? If the Honda has an automatic trunk which would be a rarety and mainly in Acura cars than you can add a relay off the DEI alarm to send a signal to the trunk release wire.
In my honda the pull lever for the truck is a manual pull, not an electric charge so I can't set it up to release from a remote. It has to be like power locks that are triggerd by a pulse.
get a trunk pop kit.i've seen them for around $30.its a big solenoid,when adding a + &- retracts.i put one on my 95 civic.hold #2 button on remote,disarms and pops trunk at the same time.
The DEI came to mind first. My girlfriend has a 97 EX with remote entry +trunk. I figure find the OEM solenoid if it's easier to install (in my EM1) than the DEI... since the DEI needs to be rigged to the release or release cable.
Pardon my ignorance, but what's an EM1? BTW, using an electronic OEM trunk opener with an aftermarket alarm will require some "rigging" as well.
Just get the kit, it's an easy install provided your alarm has remote trunk release output.
Remember most alarms only have a remote wire so you will need to rig a relay to a constant power wire or else you will repeatedly blow the alarm fuse.
You racer guys and your lingo, LOL. '99SI would have been more simple for guys like me.
The nice thing about OEM solenoids is that they make the install look cleaner. If you need the relay info, here it is:
86: 12v+ (fused)
85: Channel output from alarm (ground pulse)
30: Solenoid
87: 12v+ (fused)
86: 12v+ (fused)
30: Solenoid
87: 12v+ (fused)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi »</TD></TR><TR><TD CLASS="quote">Some alarms have +12V pulse, mine for instance</TD></TR></TABLE>
With an output current of what?
Some Honda's do have electric trunk realeases. 98 and above integra's for one.
The NSX has an electric trunck release and pulls a cable. I think it would probably be easier to use an aftermarket model just not as reliable.
zarberus
10
Feb 15, 2012 11:31 AM
Jay J
Audio / Security / Video
May 17, 2004 04:33 PM
