Idle problem
Old Jul 18, 2003 | 12:41 AM
DesiDez's Avatar
Default Idle problem
i finally finished my dohc zc swap into a 90 crx dx. the ignition timing is a bit off but before i can adjust it, i have to fix the idle.
when i start the car, the idle sits at zero. i swapped ignitors to solve the problem, but the idle sits at zero (meaning it reacts slowly when i step on the gas), but then will move normally.
i tried adjusting the idle screw, but the idle does not move. i can hear the engine change its sound but the idle still sits at zero.
i checked the vacuum hoses but everything looks right.
any other suggestions. it worked a couple of days ago but it started acting this way after i had pulled one of the vacuum hoses off the intake mani.
Old Jul 20, 2003 | 08:54 PM
DesiDez's Avatar
Default Re: Idle problem (FOBsquad)
anybody have any suggestions?
Old Jul 20, 2003 | 10:22 PM
Ryan C's Avatar
vacumn lines suck...free bump good luck
joelmatt89
13
Mar 9, 2009 07:03 AM
90si-rex
Jul 27, 2006 05:54 PM
speedfanatic88
15
Aug 23, 2004 03:12 PM
Tony92lude
Mar 1, 2004 06:38 AM
