REALLY CHEAP rubber couplings for IC pipes at MENARDS! (same as home depot)
Old Jul 17, 2003 | 08:20 PM
racinskittle's Avatar
Default REALLY CHEAP rubber couplings for IC pipes at MENARDS! (same as home depot)
I figured I'd let you guys know about this since i've been receiving all this help lately
If you have a Menard's by you, go to it and get your rubber couplings there!
THey're only $1.84! (got 4 for $7.77 not bad)
I stopped at Home Depot today, and the same ones were almost $5! Also, they're listed as 2" but they work for 2.25 no problem and when my JCwhitney pipes get here ill see if they work on 2.5 inch as well. Im hoping it does.
Well just figured i'd let you guys know.
3" to 2" reducers 3.29 about
3" to 3" is about $3-4 as well.
-Dan
Old Jul 17, 2003 | 08:25 PM
Accord94DX's Avatar
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (racinskittle)
those blow up under boost. good for n/a intakes.
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (Accord94DX)
they do?? ****. Under how many PSI?
Old Jul 17, 2003 | 08:27 PM
lazerus's Avatar
much more than 10 psi and they will blow... they will rip to shreds if you try and run 20+ psi :-P
Old Jul 17, 2003 | 08:29 PM
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (lazerus)
well ill keep it at 10 and keep my fingers cross
Old Jul 17, 2003 | 08:37 PM
Flamenco-T's Avatar
they'll blow up...I have seen blowing up at 6-7 psi...
they are meant to hold PVC pipes with no movement at all, compeltely different applications...
home depot for home usage again, invest in silicone couplers, and have trouble free experience in the future...it's not worth to be driving around in a hot weather to have to stop on the side of the freeway fixing charge pipe..
stan
Old Jul 17, 2003 | 09:02 PM
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (Flamenco-T)
LOL thanks DOH gotta see if a mod can lock this then
Old Jul 17, 2003 | 10:44 PM
flip1199's Avatar
yea they will blow apart and rip. I know from experience. I went to the track with those on my car. Out of 7 runs i went through 4 of those damn things. Not one of them lasted a whole 1/4 mile I'm also only boosting .4bar. If you can take them back. either that or you better wrap those things with duct tape and pray.
Old Jul 17, 2003 | 11:05 PM
RuthlessEF-9's Avatar
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (flip1199)
don't go cheap on your project take the time to save up a little extra cash and do it right
Old Jul 18, 2003 | 05:43 AM
ricodemus's Avatar
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (D16z6turbs)
Are these any good? They don't look to have multiple ply's, but I would only be using these for the charge pipe.
http://cgi.ebay.com/ebaymotors...09169
Old Jul 18, 2003 | 09:06 AM
ion_four's Avatar
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (ricodemus)
Wow, all you guys must have some facked homedepot and autoparts stores where you live...I have been running radiator house couplings and a drain pipe recucer at the throttle body for almost a year between 5-12 psi and haven't ever had a problem.
Old Jul 18, 2003 | 11:27 AM
flip1199's Avatar
Default Re: REALLY CHEAP rubber couplings for IC pipes at MENARDS! (ion_four)
radiator hose is alot different then a regualar rubber. radiator hose is braided and ment to take some pressure and heat, unlike the home depot regular rubber coupling.
Old Jul 18, 2003 | 11:31 AM
phiberoptik's Avatar
hey be glad you didnt buy the home depot ones...
ive seen people use the rubber ones and they hold up to 10 psi no problem and others cant even keep silicone ones on... depends on fitment and pipe movement a little also.
Old Jul 18, 2003 | 11:32 AM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">...it's not worth to be driving around in a hot weather to have to stop on the side of the freeway fixing charge pipe..
stan
aint that a bitch... without gloves... at night
Old Jul 18, 2003 | 07:13 PM
Hey what kind of radiator hose do you get. I too those PO's back today. Got myself some JB weld instead lol. "The beginning of a failure" = Name of my turbo project
Old Jul 18, 2003 | 07:21 PM
Trac226's Avatar
JB weld is no no on that oil return. It cost me like $5 to get the fitting welded to my oil pan. Hehe, that's almost as much as buying the jb weld.
StrokedPSI
Nov 23, 2004 09:00 AM
Racerage1
May 11, 2003 07:09 AM
boost killz
Feb 24, 2002 11:48 PM
