Rad hose size problems....B-series in a EK civic....
Old Jul 17, 2003 | 07:19 PM
Petah's Avatar
Default Rad hose size problems....B-series in a EK civic....
I am in the last stage of doing a swap and we notice when hooking up the GSR rad hoses to the stock rad, the rad inlet and outlet are actually smaller than the rad hose. The factory spring clamps will not seal the hoses. Has anyone faced this problem? One of my friend suggested to use the screw type clamp and clamp it down but i am little weary of doing so. Anyone has done this before? Will there be any problems?
I also heard that the SI/SIR coupe rad is the same rad as the regular civic but with larger inlets and outlets....can anyone verify this?
Thanks.
Old Jul 17, 2003 | 07:22 PM
eg6h8k's Avatar
Default Re: Rad hose size problems....B-series in a EK civic.... (Petah)
the screw type is fine...easier to work w. imo..i hate those damn clamps..i try to replace all the clamps w. screw type...
Old Jul 17, 2003 | 08:52 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Rad hose size problems....B-series in a EK civic.... (eg6h8k)
i got some gasket maker or whatever liquid stuff and i out it around the the outlets of the radiator itself and i got the screw type clamps....i let it sit for about an hour and everything worked fine....i had that same problem when is witched radiators
Old Jul 17, 2003 | 11:51 PM
salbaje's Avatar
yes buy the screw type clamps and your problems will be solved. make sure they dont leak when installed
Old Jul 17, 2003 | 11:54 PM
CivicNA's Avatar
Default Re: Rad hose size problems....B-series in a EK civic.... (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje &raquo;</TD></TR><TR><TD CLASS="quote">yes buy the screw type clamps and your problems will be solved. make sure they dont leak when installed</TD></TR></TABLE>
Old Jul 17, 2003 | 11:55 PM
ransack's Avatar
Raditor hoses right?
Use Del Sol VTEC hoses.
Akai Star
Apr 6, 2010 09:05 AM
invisible
12
May 30, 2007 03:41 PM
invisible
May 29, 2007 01:03 PM
nebulight
Sep 4, 2006 11:14 PM
hondastreet
Mar 17, 2004 09:32 AM
