Rad hose size problems....B-series in a EK civic....
I am in the last stage of doing a swap and we notice when hooking up the GSR rad hoses to the stock rad, the rad inlet and outlet are actually smaller than the rad hose. The factory spring clamps will not seal the hoses. Has anyone faced this problem? One of my friend suggested to use the screw type clamp and clamp it down but i am little weary of doing so. Anyone has done this before? Will there be any problems?
I also heard that the SI/SIR coupe rad is the same rad as the regular civic but with larger inlets and outlets....can anyone verify this?
Thanks.
Thanks.
Re: Rad hose size problems....B-series in a EK civic.... (Petah)
the screw type is fine...easier to work w. imo..i hate those damn clamps..i try to replace all the clamps w. screw type...
jus f0 dekarayshunZ
Re: Rad hose size problems....B-series in a EK civic.... (eg6h8k)
i got some gasket maker or whatever liquid stuff and i out it around the the outlets of the radiator itself and i got the screw type clamps....i let it sit for about an hour and everything worked fine....i had that same problem when is witched radiators
yes buy the screw type clamps and your problems will be solved. make sure they dont leak when installed
Re: Rad hose size problems....B-series in a EK civic.... (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje »</TD></TR><TR><TD CLASS="quote">yes buy the screw type clamps and your problems will be solved. make sure they dont leak when installed</TD></TR></TABLE>
Akai Star
04-06-2010 09:05 AM
invisible
12
05-30-2007 03:41 PM
hondastreet
03-17-2004 09:32 AM
