what mount kit is everybody using?
Old Jul 17, 2003 | 06:24 PM
eddiecut's Avatar
Default what mount kit is everybody using?
just have an 92 hatch and just wondering what mounts ppl are using for a dohc motors
thanks
Old Jul 17, 2003 | 06:28 PM
built562's Avatar
Default Re: what mount kit is everybody using? (eddiecut)
i am using oem eg motor mounts with prothane inserts.
a little rough at idle and take off but i like it
Old Jul 17, 2003 | 06:31 PM
mysideperformance's Avatar
hasport.com
Old Jul 17, 2003 | 06:35 PM
94si94cx's Avatar
Default Re: what mount kit is everybody using? (mysideperformance)
You don't need a mount "kit". You use Integra mounts for a b-series into an EH2 chasis. 3 Integra mounts and 2 Civic mounts to be exact.
Old Jul 17, 2003 | 06:51 PM
viet's Avatar
Default Re: what mount kit is everybody using? (94si94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx &raquo;</TD></TR><TR><TD CLASS="quote">You don't need a mount "kit". You use Integra mounts for a b-series into an EH2 chasis. 3 Integra mounts and 2 Civic mounts to be exact.</TD></TR></TABLE>
Old Jul 17, 2003 | 06:56 PM
eddiecut's Avatar
Default Re: what mount kit is everybody using? (viet)
ok what mounts are they because, i have a full integra mount kit and for some reason its not working, iam thinking maybe i got sent mis matched mounts but not sure.
Old Jul 17, 2003 | 06:57 PM
94si94cx's Avatar
Rear, Timing belt side, and lower transmission mounts should all be Integra
A/C mount and upper transmission mount should be Civic.
Old Jul 17, 2003 | 06:59 PM
TrickHonda98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysideperformance &raquo;</TD></TR><TR><TD CLASS="quote">hasport.com </TD></TR></TABLE>
Old Jul 17, 2003 | 07:08 PM
eddiecut's Avatar
Default Re: what mount kit is everybody using? (TrickHonda77)
the problem iam having is that the tranny mount for some reason doesnt work right, its for sure a b series, the bolt wont go all the way threw. and the bottom tranny mount wont work either, i even tried a jim fab mount on that one.
Old Jul 17, 2003 | 07:10 PM
94si94cx's Avatar
The bottom tranny mount should work. Its 3 bolts into the tranny if I remember correctly.
The top tranny mount should be from your Civic, not from an Integra.
Old Jul 17, 2003 | 09:29 PM
turboedsi's Avatar
Hasport !!! i got the whole kit for my b16/si
GF likes it, she says its like a vibrator.
strictly.business
May 2, 2006 11:40 PM
dso
Dec 2, 2004 05:15 PM
Disco Monkey
May 3, 2004 04:49 PM
92Integra
Feb 26, 2004 10:06 PM
