My gas pedal is semi stuck! Adjustment?
Old Jul 17, 2003 | 04:32 PM
B2FiNiTY's Avatar
Default My gas pedal is semi stuck! Adjustment?
Can I adjust this? From a stand still it is very stiff and I have to ride the clutch all the time when starting and going. Very very annoying.
Old Jul 18, 2003 | 03:44 AM
keithv's Avatar
Default Re: My gas pedal is semi stuck! Adjustment? (B2FiNiTY)
check the movement of the cable at the manifold end. it might just need some grease to lubricate it.
Old Jul 18, 2003 | 04:55 AM
bagged89hatch's Avatar
Default Re: My gas pedal is semi stuck! Adjustment? (keithv)
Try what keith said first if that does not solve the problem then chances are that your throttle body has developed a ridge on the inside where the butterfly comes to rest. it can be fixed if you remove the throttle body and lightly sand away the ridge. I had this happen on a few cars anr it was very frustrating. If you take off your intake tube, open the butterfly all the way and stick your finger in you should be able to feel if there is a ridge in there it will be sharp so be carefull!!! let me know what you find.
Old Jul 18, 2003 | 12:39 PM
H22AEG2's Avatar
Default Re: My gas pedal is semi stuck! Adjustment? (bagged89hatch)
Check the pedal where the cable attaches to it and see if the plastic clip came loose. Hopefully you are not squooshing it when you press the pedal.
Old Jul 18, 2003 | 05:32 PM
B2FiNiTY's Avatar
Where exactly should I grease it up?
Old Jul 18, 2003 | 07:20 PM
FourthGenHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Where exactly should I grease it up?</TD></TR></TABLE>
Lube it on all the exposed part of the cable then press the pedal so the grease gets sucked inside the covered up parts and that should lube it up. Mine used to stick at stop lights and idle at like 1500 and I would have to pull the pedal back with my foot and it would go to normal. I greased it up inside and out and it was good.
Old Jul 18, 2003 | 11:36 PM
B2FiNiTY's Avatar
Default Re: My gas pedal is semi stuck! Adjustment? (FourthGenHatch)
I will be doing that as soon as possible. Very very annoying. I checked it out and it is way too dry. Thanks for the help guys.
Old Jul 21, 2003 | 11:44 PM
B2FiNiTY's Avatar
Greased it but it is still stuck!
Old Jul 22, 2003 | 03:26 AM
keithv's Avatar
grease the actual cable...you should see it attached to the spring you greased.
Old Jul 22, 2003 | 04:19 AM
im telling you the butterfly is sticking inside the TB. Try what keith said first if that does not solve the problem then chances are that your throttle body has developed a ridge on the inside where the butterfly comes to rest. it can be fixed if you remove the throttle body and lightly sand away the ridge. I had this happen on a few cars anr it was very frustrating. If you take off your intake tube, open the butterfly all the way and stick your finger in you should be able to feel if there is a ridge in there it will be sharp so be carefull!!! let me know what you find.
Old Jul 22, 2003 | 01:41 PM
B2FiNiTY's Avatar
I will try keith's suggestion and see if it helps. If not, I will wait till I get the stock intake to mess with the TB.
Old Jul 24, 2003 | 05:32 PM
B2FiNiTY's Avatar
It has nothing to do with the butterfly. I checked that yesterday. It is totally fine inside besides being really dirty.
I still have to find my grease again and try greasing up the throttle cable some more.
Old Jul 24, 2003 | 09:33 PM
what happenes if you try to turn the throttle byhand on the side of the TB where the cable connects
Old Jul 25, 2003 | 10:50 AM
B2FiNiTY's Avatar
I will check that. When I pull the cable it seems fine.
Old Jul 25, 2003 | 10:26 PM
B2FiNiTY's Avatar
New news:
When I press the gas while the car is off and sitting for awhile, it is completely smooth. Once I start driving it becomes stuck.
Old Aug 1, 2003 | 01:43 PM
well did you get it fixed
Old Aug 1, 2003 | 06:52 PM
B2FiNiTY's Avatar
I found the grease. I will be trying to grease it tonight.
Old Aug 1, 2003 | 11:00 PM
raene's Avatar
Haha, that's a long time to find grease
If it gets harder when the car's warmer I'd think that it has to do with metal expansion due to heat, ie the butterfly expanding that extra 0.1mm and catching on the inside of the TB or something... I dunno.
Old Aug 2, 2003 | 12:37 AM
HF2ZC's Avatar
This is going to sound dumb, but get some throttle body cleaner and clean the throttle body. It worked on a friend of mine's 88 Si.
Old Aug 2, 2003 | 04:03 PM
B2FiNiTY's Avatar
Default Re: My gas pedal is semi stuck! Adjustment? (HF2ZC)
Do you spray and then what? I'm not sure how to use the intake manifold cleaner either. I heard it makes the car run really rough and smoke for alittle awhile.
Old Aug 3, 2003 | 11:24 AM
raene's Avatar
You warm the car up, then remove the air intake from the TB, start the car, and while it's running fire the TB cleaner into the intake while working the butterfly back and forth (ie revving it). Then put the intake back on (without stopping the car) and drive it right away to clean out all the TB cleaner.
Old Aug 3, 2003 | 11:27 AM
blah13's Avatar
Default Re: My gas pedal is semi stuck! Adjustment? (raene)
After doing that would you want to reset the ecu since the airflow was way up with the tube off or since it was warmed up would it not mess up its settings? Kinda like resetting the ecu after you add an intake. Just curious.
Old Aug 5, 2003 | 08:26 AM
raene's Avatar
Default Re: My gas pedal is semi stuck! Adjustment? (blah13)
It shouldn't raise the idle to have the intake tube off, really. As far as the ECU knows you're just revving the engine!
Old Aug 11, 2003 | 01:22 PM
B2FiNiTY's Avatar
*UPDATE*
I greased everything up and it still gets stuck.
I ordered some throttlebody/intake manifold cleaner from honda. Hopefully that will do the tricl.
honda00b16
Oct 27, 2010 12:20 PM
VietCloud7
May 6, 2008 04:46 PM
mr poo
15
Jun 14, 2006 08:09 PM
VtecBrian
Feb 20, 2006 06:01 AM
Yeung
Jun 3, 2004 09:12 PM
