Can you fully tune your hondata on the street without a dyno??
Old Jul 17, 2003 | 10:55 AM
accordfreak's Avatar
Default Can you fully tune your hondata on the street without a dyno??
i'm going to a shop that doesn't have a dyno but they said they can fully tune on the street. partial throttle, WOT, and with boost.. on a wideband o2 .. They also said it is going to take around 6 hours to do. does this sound about right? please confirm.. thanks!
Modified by accordfreak at 12:07 PM 7/17/2003
Old Jul 17, 2003 | 10:59 AM
Dee's Avatar
Dee
Default Re: Can you fully tune your hondata on the street without a dyno?? (accordfreak)
If you have a deserted open area and a wide band o2 you can pull off a no-dyno tune with no problems. BUT seeing the power/torque curves aids the fine tuning sessions.
Old Jul 17, 2003 | 11:22 AM
RicerRacing69's Avatar
6 hours doesnt sound right. They must not know what the hell they are doing. It should take about 1-3 hours at most w/o a dyno.
Old Jul 17, 2003 | 11:38 AM
PM-Performance's Avatar
Default Re: Can you fully tune your hondata on the street without a dyno?? (RicerRacing69)
whats Boosted Hybrid does on his cars is does the partial thorttles on the streets and soem full thorttle pulls, and thne fine tunes for like and hr or so on the dyno to get the timing maps tweaked for full power.
Old Jul 17, 2003 | 11:40 AM
alpha's Avatar
I would be willing to bet 6 hours is a guess. They probably don't want to tell a customer it will take an hour or two when there could be problems.
Old Jul 17, 2003 | 11:48 AM
01ITR#700's Avatar
Default Re: (0x64)
FWIW I had my car tuned w/ Hondata strictly on the street, and I'm extermely happy with it. I do plan on putting on a dyno here soon in order to fine tune it.
HTH
Mark
Old Jul 17, 2003 | 12:12 PM
sharkcohen's Avatar
You can do quite a bit on the street with a wideband, but you cannot easily fine tune the timing without seeing the power output on a dyno.
Old Jul 17, 2003 | 12:13 PM
ekb18c's Avatar
Tuning on the street is actually better then the dyno, it's just too bad that it gets dangerous when the car is at WOT.
Old Jul 17, 2003 | 12:31 PM
vtec.dc2's Avatar
its better to get the car street tuned first and dyno tuned later.. and it shouldn't take more than 2-3 hours for street and 1 hour for dyno unless you're running lots of boost then it might take a little longer on dyno.
not that it could hurt to street tune for 6 hours, but if the tuner does take that long, he's still learning to tune, and should do the first 3-4 hours for free...
Old Jul 17, 2003 | 01:43 PM
Default Re: Can you fully tune your hondata on the street without a dyno?? (vtec.dc2)
this tuner is doing it for a flat fee of 250 dollars... i tried scheduling last month but he's booked until july 29th.. so I assume he's good for the amount of customers he gets.. plus got a couple reviews... so it's not possible to fine tune the timing on the street? BTW: i'm tuning at 1 bar..
Old Jul 17, 2003 | 02:43 PM
JMinSi2000's Avatar
$250 is a good price. I think most guys charge something like $150 an hour.
Old Feb 15, 2004 | 10:30 PM
1SlowSi's Avatar
Default Re: Can you fully tune your hondata on the street without a dyno?? (JMinSi2000)
So basically street tuning is the best and the only way to get part throttle tuning done, And then the Dyno is good for WOT and fine tuning.. So pretty much do both right??? How good of a tune can you get doing WOT on the street?
Old Feb 16, 2004 | 12:06 AM
DLB1994's Avatar
Default Re: Can you fully tune your hondata on the street without a dyno?? (1SlowSi)
i dont see how i could street tune my car maybe if am doing 5th gear pulls , 3rd and 4th gear pulls will be spining or just going way to fast, maybe if i had salt flats here in va
Old Feb 16, 2004 | 12:21 AM
Default Re: Can you fully tune your hondata on the street without a dyno?? (DLB1994)
wow super old post.. haha
just to verify. i had my car ALL street tuned by vernon at raver motorsports to 9psi. no problems whatsoever during the couple months. Then I had jason (st00pid) tuned the rest of the map to 14psi.. he said my previous tune was really good.
fastitr01
May 16, 2004 11:10 PM
xXx Justin xXx
May 13, 2003 12:07 PM
p1ccoloz
Feb 12, 2003 10:07 AM
GOKOU
Oct 9, 2002 06:33 AM
GruvyTune
Apr 27, 2002 01:56 PM
