Finanally Got The R Tuned..
Old Jul 17, 2003 | 07:21 AM
sicklexus1's Avatar
Default Finanally Got The R Tuned..
Well I finanall took my car to get tuned and dyno'd at Jotech in Garland.
I am just wondering if this sounds about right.
01 ITR
DC JDM 4-1 header
AEM cold air intake
Skunk 2 stage II cams
Skunk 2 retainers and valve springs
Skunk 2 cam gears
Apexi VAFC
B&M fuel pressure regulator
With all of this my base run was a 163 whp and after 4 hrs of tuning all I made was 181 whp. Does that sound right? What else do I need to make AT LEAST 200?
Thanks
Bonnie
Old Jul 17, 2003 | 07:23 AM
EleanoR's Avatar
Default Re: Finanally Got The R Tuned.. (bonnieornelas)
numbers sound about right. do you have an exhaust? that would free up some hp. that is what is holding me back right now. i have similiar mods and a stock exhaust with Carsound highflow cat and DC JDM.
Old Jul 17, 2003 | 07:27 AM
RTW DC2R's Avatar
Default Re: Finanally Got The R Tuned.. (EleanoR)
sounds decent for stock compression. a nice catback would probably help out some as well
Old Jul 17, 2003 | 07:28 AM
Mires's Avatar
How was your experience at Jotech? How was the tuner? I am trying to find a good tuner and am in a driving distance away from there.
Old Jul 17, 2003 | 07:36 AM
sicklexus1's Avatar
Default Re: Finanally Got The R Tuned.. (Mires)
The shop was awesome. Kenny Tran was the person that tuned it. I would recomend you go there. They explain everything to you. I drove there 7 hrs just becasue I heard they were good. And I was really satisfied.
Old Jul 17, 2003 | 07:37 AM
obd2gsr's Avatar
looks good! a good cat back should free up some more hp.
Old Jul 17, 2003 | 07:38 AM
MPH's Avatar
MPH
New User
I put down 197 with stage 2's, stock compression and bolt on's before I bent all the intake valves 5 passes later. Sounds like you can get more hp out of her.
Old Jul 17, 2003 | 07:53 AM
Hybrid 350GT's Avatar
Default Re: Finanally Got The R Tuned.. (MPH)
I think you could squeese some more out. I had 175 whp with some heavy 18" rims, VAFC, Short ram intake, stock headers and exhaust, aem cam gears, and an AEM FPR. But then again each Dyno seems to show different numbers. There was something in Super Street or something like that, they brought a stock 350Z to like 6 different dynos. There was a 40whp difference between the highest and lowest dyno numbers.
Old Jul 17, 2003 | 07:58 AM
00MRSi's Avatar
Default Re: Finanally Got The R Tuned.. (DOSPOWND)
A free-flowing (2.5") exhaust and a better flowing header would help.
Old Jul 17, 2003 | 08:03 AM
whitelightning's Avatar
Default Re: Finanally Got The R Tuned.. (00MRSi)
how much did it cost ya? 4 hrs of tuning?
Old Jul 17, 2003 | 08:24 AM
RockstarJR's Avatar
It could be the dyno...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOSPOWND &raquo;</TD></TR><TR><TD CLASS="quote"> I had 175 whp with some heavy 18" rims</TD></TR></TABLE>
What does wheel weight have to do with on the dyno?
Old Jul 17, 2003 | 09:10 AM
sicklexus1's Avatar
Default Re: Finanally Got The R Tuned.. (ITRChris)
Any suggestions on what else I need. I am wanting to do ecu, injectors, fuel pump, and exhaust. Which ones do you recomend?
Another quick qustion. Since these cams keep making hp, they dyno was just pushed to 7800-8000 rpm would it still be capable of more hp since I can push it to 9000?
Modified by bonnieornelas at 10:24 AM 7/17/2003
Old Jul 17, 2003 | 09:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRChris &raquo;</TD></TR><TR><TD CLASS="quote">It could be the dyno...
What does wheel weight have to do with on the dyno? </TD></TR></TABLE>
Harder for the motor to spin 50lbs of metal rather than 20lbs. I'd assume that would affect a dyno run a little bit.
Old Jul 17, 2003 | 09:34 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonnieornelas &raquo;</TD></TR><TR><TD CLASS="quote">Any suggestions on what else I need. I am wanting to do ecu, injectors, fuel pump, and exhaust. Which ones do you recomend?
Modified by bonnieornelas at 10:24 AM 7/17/2003</TD></TR></TABLE>
stock injectors and fuel pump will be fine for your stock compression. If you increase compression you will want to think about injectors, but stock pump would probably still be fine(it is for me so far). As far as how high to rev, get on the dyno, and put the rev limiter where the cams stop making/holding power. just because you can theoretically rev to 10grand, doesnt mean you are making any power that high. you can see on the dyno where you power begins to fall off and set your rev limit near that.
Old Jul 17, 2003 | 10:55 AM
sicklexus1's Avatar
Default Re: Finanally Got The R Tuned.. (RTW DC2)
The hp never drops at 7800-8000 rpm. The dyno is stopped. hp keeps climbing. Thats why I was womdering about if it is capable of more whp. I heard stage II keep making horspower up to 92-9400 rpm.
Modified by bonnieornelas at 12:10 PM 7/17/2003
Old Jul 17, 2003 | 11:41 AM
fuck honda-tech's Avatar
kinda off topic... but how do u like the skunk2 cams?
Old Jul 17, 2003 | 11:59 AM
STOLEN - ITR 98-0652's Avatar
Compression is your friend. You'd be amazed what the mid-11s would do.
themilman
Jul 22, 2005 11:26 PM
sicklexus1
Oct 1, 2003 03:36 PM
sicklexus1
Aug 16, 2003 12:20 PM
sicklexus1
Jul 16, 2003 12:56 PM
TeamTooQuick
May 9, 2002 09:00 PM
