Next mod...
Old May 9, 2002 | 03:20 PM
TeamTooQuick's Avatar
Default Next mod...
Ok, i already got new struts, springs, and AEM CAI... Some people r tellin me fuel, like fuel rail, injectors, then some people say get the Skunk 2 IM, Skunk 2 Stage 2 cams, retainers, springs, what should i do first???
Old May 9, 2002 | 03:46 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Next mod... (TeamTooQuick)
Don't get the skunk manifold. I would get JDM headers and a high flow cat, then exhaust
Old May 9, 2002 | 04:00 PM
fiebru1119's Avatar
what are your goals?
Old May 9, 2002 | 04:05 PM
IgniteTeg's Avatar
Default Re: Next mod... (fiebru1119)
What are your plans really man???? FI????? If you are mind as well try and save up for the turbo If your all N/A then my suggestion is a good high flow header cat, and an exhaust. JDM 4-1, Carsound Cat, Apexi N1 which is what I got or you can get TRM or others depends on your taste. Then after that you should get a vafc, cams, gears, list goes on........ Plan your goals first.
Old May 9, 2002 | 05:03 PM
threatcon13's Avatar
New User
Default Re: Next mod... (IgniteTeg)
header and exhaust...why tune the flow of fuel when all you have is an intake
Old May 9, 2002 | 05:15 PM
I Drive A Saturn's Avatar
i agree with ignite...figure out whether you want to go NA or FI. that decision will pretty much play out what mods you should/need to do in the future.
-jeremy
Old May 9, 2002 | 06:07 PM
frogsr's Avatar
Default Re: Next mod... (ALLMOTORDC2)
agreed. the stock fuel rail is very adequate for ~200 whp, so getting an aftermarket one now would be overkill. the intake manifold should be had when you have some nice cams.
Old May 9, 2002 | 06:10 PM
Goy091's Avatar
yea get the rest of the engine breathing done. header,highflow cat, catback. then id go with the valvetrain (springs,retainers,maybe valves depending), cams, cam gears, fpr, vafc and some dyno time. i dont think you really need bigger injectors or a fuel rail unless you get some big cams. ie skunk2 stage3 and such.
oh btw i think youll have to get an ITR CAI if you get the skunk2 IM.
[Modified by Goy091, 3:11 AM 5/10/2002]
Old May 9, 2002 | 06:24 PM
KooK's Avatar
Mustang Sally
Default Re: Next mod... (Goy091)
I say get a Spoon 70mm Throttle body and a type R IM (or will that not fit because its a c5?). But yes, work on letting your engine breathe first! *as in, get your exhaust "fixed"!*
http://www.inlinefour.com/spoon70throt.html
[Modified by Tapeworm, 9:25 PM 5/9/2002]
Old May 9, 2002 | 06:32 PM
startroops's Avatar
Default Re: Next mod... (Tapeworm)
I don't know, personally I'd rather get the exhaust before headers, but that's just me. (Especially when my Midas exhaust cracked).
Wait til you get cams, then fuel rail + FPR
Old May 9, 2002 | 09:00 PM
Default Re: Next mod... (startroops)
im stayin NA for now....
flippedoutasian
May 4, 2004 01:51 AM
sicklexus1
Jul 17, 2003 11:59 AM
WannAbe_DC5
Sep 8, 2002 08:46 PM
Smitdog
Aug 22, 2002 10:27 AM
96_GSR
Jun 18, 2002 07:15 AM
