Good by ZC hello B16.
Old Jul 17, 2003 | 03:44 AM
7PSiEF9ZC's Avatar
Default Good by ZC hello B16.
After blowing up my turbo ZC motor I'm done with ZC's and now switching to B series. I've messed and tuned ZC's for the last three years and I'm now gonna go B series. I'm ONLY using the B16 for now just to get my car back on the road. I'm building up a LS block on the side and it'll end up being LS/VTec. I picked up my B16 yesterday. I got a OBD1 Cable YS1 " LSD " XS-i motor. How do I know. There's alittle serial number under the word " B16A" if it starts with a 1 you have a integra motor if it starts with a 5 you have a civic motor. I have everything switched over so I can run the motor as a OBD0 motor for now and when I got LS/VTec I will be changing over my EF to a OBD1 set-up and get that 10HP that everyone talks about thats not why I changing the OBD set-up though. Also I decided to get a OBD1 cause one I wanted the LSD trans , Two it's alittle newer and usually not as old or ragged out like the Gen. 1 B16's , and three this way I have everything needed to switch to OBD1. I'm using a OBD0 injectors , dizzy , and a PR3 ECU. I do 100% all my own work so I'll have pic.'s up soon of the motor and install.
Old Jul 17, 2003 | 04:19 AM
onetwothree's Avatar
Default Re: Good by ZC hello B16. (7PSiEF9ZC)
Congrads to the wise up, good luck and have fun!
Old Jul 17, 2003 | 06:20 AM
crxchris's Avatar
how can u tell its a lsd trans i thought all ys1 cable trans were non-lsd
Old Jul 17, 2003 | 06:53 AM
Default Re: (crxchris)
I'm not sure but I think it says lsd on the casing.
Old Jul 17, 2003 | 07:04 AM
nuc79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxchris &raquo;</TD></TR><TR><TD CLASS="quote">how can u tell its a lsd trans </TD></TR></TABLE>
With the axles out, you can look straight through the differential, and there's not a bar in the middle.
Old Jul 17, 2003 | 07:58 AM
crxchris's Avatar
is there any way to tel from the casing it doesnt say lsd anywhere i can see where should i look and can u tell from the id tag that says ys1 on it? thanks. didnt mean to jack thread at all
Old Jul 17, 2003 | 09:42 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxchris &raquo;</TD></TR><TR><TD CLASS="quote">is there any way to tel from the casing it doesnt say lsd anywhere i can see where should i look and can u tell from the id tag that says ys1 on it? thanks. didnt mean to jack thread at all </TD></TR></TABLE>
Fro my understanding it should say "LSD" on the top of the tranny casing, visible fromm when you pop your hood (I think).
Old Jul 17, 2003 | 03:24 PM
7PSiEF9ZC's Avatar
Default Re: (Mr. S)
Yes they do say it on the casing but thats not a reliable way to tell if it's a LSD or not. Just take off the inner joint on the trans most should come right off on the NON-Intermediate shaft side and just look inside the trans. If you see a big BAR in the middle of the trans it's a non-LSD trans. If you can see straight threw the trans and there's not a bar in the middle of the diff. you have a LSD trans my friend. When I post pic.'s of everything I'll show you what I mean.
Old Jul 18, 2003 | 05:38 AM
crxchris's Avatar
plaese do post pics and thats the only reliable way to tell? no external cues other than casing stamp?
Old Jul 18, 2003 | 08:12 AM
raene's Avatar
CORRECT. Everything else can be faked by someone of ill repute that wants to make a little extra $$$ by selling you a non-LSD trans badged as having an LSD.
Old Jul 18, 2003 | 09:40 AM
Lightning Lover.'s Avatar
awesome dude
Old Jul 18, 2003 | 10:18 AM
CRXtacy's Avatar
Whatcha doin with the turbo set-up?
sublimeh215
Jan 29, 2010 06:41 AM
7PSiEF9ZC
Jul 17, 2003 06:21 PM
7PSiEF9ZC
Jul 16, 2003 09:37 AM
7PSiEF9ZC
Jul 15, 2003 09:33 PM
t0eKnEe
17
May 5, 2003 08:26 PM
