oil pump??
Old Jul 17, 2003 | 02:34 AM
iwouldHITit's Avatar
Default oil pump??
how do you know when your oil pump is bad..i have a b18b.. and is the gasket reusable?
Old Jul 17, 2003 | 04:11 AM
1bad-eg's Avatar
Default Re: oil pump?? (iwouldHITit)
Could be different ways. The pump could not be building oil pressure cause the oil pump gear is bad, or if it is clogged somewhere. It sounds like you're having oil pressure issues. Another thing to look at is by dropping the oil pan and checking to see if the oil pickup is clogged or if there is debris. That can restrict flow. Hope this helps.
oscar112709
Apr 18, 2019 12:52 AM
Tzarinque
Sep 19, 2008 09:59 PM
highcomp
Apr 7, 2004 10:45 PM
sk8rmike
Oct 8, 2003 08:41 PM
Tofurky
Jun 23, 2003 12:44 PM
