Oil Pump Removal
Re: Oil Pump Removal (95dxsir2)
my mistake. Well there's oil coming from that general area. It's either squirting out of the oil pump where the orings are or its leaking out the crankshaft front oil seal. There's no easy way to do this is there?
Re: Oil Pump Removal (Tzarinque)
so obviously its not the pump, try running the car and see if you can see where it comes out at. clean the area first.
Re: Oil Pump Removal (Spool This)
why is it obviously not the pump. It only leaks when the car is running, oil pumps have pressure in them when the car is on, therefore it's gotta be the pump
do you know where its leaking from? cause without pressure the oil pump wouldn't pump anything anywhere to leak from. oil light on? maybe check up top around cam.
