Axle Problem!!!! HELP!!
Old Jul 16, 2003 | 07:26 PM
Egone's Avatar
Default Axle Problem!!!! HELP!!
i just changed the cv joint boots and i cant get the axle to pop back in the tranny ....
Old Jul 16, 2003 | 07:27 PM
Egone's Avatar
Default Re: Axle Problem!!!! HELP!! (Egone)
https://honda-tech.com/zerothread?id=382416&page=1
im on step 15
Old Jul 16, 2003 | 08:55 PM
Egone's Avatar
ttt plz help i need my car out for work/school
Old Jul 16, 2003 | 09:03 PM
im_poor's Avatar
did you stick the correct splined end in??
Old Jul 16, 2003 | 10:52 PM
aw1234dude's Avatar
Default Re: Axle Problem!!!! HELP!! (im_poor)
I just swapped in a b16 in my hatch and i reversed the axles which made one side go in all the way and one side go in about an inch. I realized it was going in any further and pulled both out and inspected them. One azle had splines running down the whole length of the shaft that slides into the tranny and the other had splines on half of the shaft. I then switched the axles and put the one with half the splines in the driverside and put the one with the full splines on the passenger side.
Its kind of tricky to get the whole axle into the hole because itll go half way and then want to stop. Theres a lock ring thing on the end which makes it so popping the axle the rest of the way in slightly difficult. I used the good old push and shimmy techniqe. Itll just pop right in.
Old Jul 17, 2003 | 11:49 AM
Egone's Avatar
yea thats the problem im having i changed the lock ring so its tight, the old lock ring was loose, anways ya im 100% sure its in the right way because i just changed the boot but what hes said is right i get it to go in but then it stops as soon as the lock ring is in the there and doesnt "pop" in
Old Jul 17, 2003 | 12:23 PM
Sketch_hs's Avatar
Default Re: (Egone)
*lightly* tap it with a rubber mallet. worked for me, brace the joint though.
keithly
Jan 15, 2017 09:23 PM
Cap'N Chronic
Jun 29, 2011 12:54 PM
jacoop86
Aug 11, 2006 04:07 PM
HGZ
Mar 8, 2005 01:12 AM
B18aTegra
May 17, 2004 05:24 AM
