AZENIS losing tire pressure when new?
Old Jul 16, 2003 | 06:17 PM
TypeR 01 886's Avatar
Default AZENIS losing tire pressure when new?
Has anybody had any experience as to the tires losing pressure when they are new. I had to fill the front tires up once since I had them put on (week ago) I am not sure if thats normal.
Old Jul 16, 2003 | 06:18 PM
Type-R Yo!'s Avatar
New User
Default Re: AZENIS losing tire pressure when new? (TypeR 01 886)
No I did not had that problem with my.
Old Jul 16, 2003 | 06:26 PM
JDM CTR '00's Avatar
check the valve stem
Old Jul 16, 2003 | 06:46 PM
vtec.dc2's Avatar
Default Re: AZENIS losing tire pressure when new? (JDM CTR '00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR '00 &raquo;</TD></TR><TR><TD CLASS="quote">check the valve stem</TD></TR></TABLE>
that or for leaks/holes in tire(s)
Old Jul 16, 2003 | 06:59 PM
Bbasso's Avatar
Or ya just ran over a nail or screw and its causing a slow leak.
inspect the tire for damage or foreign objects.
Old Jul 16, 2003 | 07:13 PM
Default Re: AZENIS losing tire pressure when new? (Bbasso)
Thanks guys for the info. I will have to look.
Old Jul 16, 2003 | 07:20 PM
Tweakmeister's Avatar
sounds like a faulty valve stem.
Old Jul 16, 2003 | 08:26 PM
CPR's Avatar
CPR
How much much psi did you actually lose in that week's time?
Old Jul 16, 2003 | 08:31 PM
Turtle's Avatar
Default Re: AZENIS losing tire pressure when new? (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a faulty valve stem.</TD></TR></TABLE>
Chances are better on the valve stem when a tire is brand new. But don't overlook a nail. Soapy water will tell you sometimes where to look...but not always on an extremely slow leak...
Old Jul 16, 2003 | 08:42 PM
CPR's Avatar
CPR
If it a valve stem, here's a check you can do.
Spit on your finger if soapy water is not available and put it around the base of the valve stem. The base is where the valve stem meets the wheel. Move the valve stem around to see if you start seeing bubbles.
Spit on your finger again and put it at the opening of the valve stem and again, see if you have bubbles.
If bubble appear at the base of the valve stem, then it was either installed wrong or your valve stem doesn't create a good seal anymore and needs to be replaced. If it's the latter, then you can get this tool where you stick it in the valve stem hole and just screw the pin inside the tube tight. If it's neither, then you got a hole in your tire and I'm sure you know how to fix that yourself.
CPR - Who's had his share of valve stem issues and they always seem to happen during track days.
Old Jul 16, 2003 | 08:47 PM
BlueR's Avatar
Default Re: AZENIS losing tire pressure when new? (CPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">CPR - Who's had his share of valve stem issues and they always seem to happen during track days. </TD></TR></TABLE>
i thought you were making excuse bc you were afraid of VIR full...lol...jfwy
uglybanter
Feb 6, 2008 04:35 PM
drewbie
31
Oct 3, 2007 07:39 AM
BDogggUT34
Nov 28, 2005 10:39 AM
Tad
Jun 21, 2004 04:08 PM
2k1 GSR
Dec 14, 2003 11:50 AM
