trans
Old Jul 16, 2003 | 03:38 PM
BigLoadChoakHard's Avatar
Default trans
can i bolt a manual tranny up to a gsr motor that came with an auto... also can u bolt a manual to any car that came auto or are the bolt patterns different from manual to auto Thanks in advance
Old Jul 16, 2003 | 03:51 PM
DJ_SaNdOz's Avatar
Default Re: trans (BigLoadChoakHard)
yes you can swap on a manual tranny. my ZC came from an auto
Old Jul 16, 2003 | 08:09 PM
CRX Si's Avatar
Default Re: trans (DJ_SaNdOz)
you will need a Manual ECU... And a munaul Tranny should go into an auto car but you will need different mounts and the shift assembly(which you may need to cut a hole for)... All the bolt holes should be on the car already... They use the same chasis for manuals and Autos... They accomodate both...
Old Jul 16, 2003 | 10:01 PM
Rywire's Avatar
Make sure you use b series trannies with b series engines, and d series trannies with d series engines. Ryan
95civic 4door lx
Aug 17, 2008 01:56 PM
JoeCDN
Sep 18, 2004 10:33 PM
turbomonkeyexpress
Nov 26, 2003 09:13 AM
Evs-One
Feb 20, 2003 02:05 AM
