89 Civic sedan woes
Old Jul 16, 2003 | 07:14 AM
Aquafina's Avatar
Default 89 Civic sedan woes
Replaced the fuel pump, that works now. The car sat around for about a year while it was being worked on, so I put 4 gallons of new gas in it. It wants to start just a little more now. Getting a new battery after I go to court tomorrow. So the only problem I'm having besides it not starting, is the main relay won't shut the hell up, it sounds like a little machine gun. The car will start but die right away. Any suggestions?
Old Jul 16, 2003 | 07:19 AM
4drEF's Avatar
Keyboard Humorist
Default Re: 89 Civic sedan woes (SuperStreetRX7)
Replace or fix the main relay.
Old Jul 16, 2003 | 09:06 AM
Aquafina's Avatar
Default Re: 89 Civic sedan woes (4drEF)
Mesa not know how to fix it, explanation?
Old Jul 16, 2003 | 10:13 AM
sleeper4dr's Avatar
here are 2 places that sell them... RZ-0063 is the number found on these
http://catalog.honda-auto-part...d.y=0
go here and click on your car, SEARCH for RELAY. under PART, click on "RELAY..." and you're looking at it.
http://www.hondaautomotivepart...-HORN
it's number 22 in this link.
and here's a link with some info about it...
https://honda-tech.com/zerothread?id=544196
hth, Jason
EDIT: for clarification on the links.
Old Jul 16, 2003 | 11:43 AM
4drEF's Avatar
Keyboard Humorist
Fix it and replace it info - with pictures!!!
http://honda.hybrids.jp/tech/p...shtml
http://www.markl.f9.co.uk/howt...y.htm
Old Jul 16, 2003 | 07:42 PM
Aquafina's Avatar
Thanks for the help. Confused my court date, it's on Friday, so I guess I'll get to work tomorrow.
Old Jul 22, 2003 | 04:54 PM
Aquafina's Avatar
Replaced the fuel pump as I said before, now that works. Replaced the battery because it wouldn't hold a charge, main relay still clicked constantly. But it won't even click after I try to start it with the new battery. Replaced the main relay with a new one and it still does the same thing.
I'm about to junk this car and take the grand I have into it as a loss. Any help would be very much appreciated.
Old Jul 22, 2003 | 06:31 PM
sleeper4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperStreetRX7 &raquo;</TD></TR><TR><TD CLASS="quote">Replaced the fuel pump as I said before, now that works. Replaced the battery because it wouldn't hold a charge, main relay still clicked constantly. But it won't even click after I try to start it with the new battery. Replaced the main relay with a new one and it still does the same thing.
I'm about to junk this car and take the grand I have into it as a loss. Any help would be very much appreciated.</TD></TR></TABLE>
sounds like the reason your main relay was clicking in the first place was due to your battery. dead batteries and bad grounds can cause the relay to do that.
what does the car do now? any codes? checked all of your fuses?
you turn the key to start and the CEL comes on for 2 seconds and the relay DOES click on to prime the fuel system right?
Old Jul 22, 2003 | 07:18 PM
Aquafina's Avatar
Default Re: 89 Civic sedan woes (sleeper4dr)
Replaced the battery but the relay still sounds like a machine gun. CEL stays on. Can hear fuel pump whir.
Old Jul 23, 2003 | 08:30 AM
Aquafina's Avatar
Any thoughts?
spens 91 Ef
Jun 17, 2015 12:25 PM
nismogrendel
Apr 24, 2010 01:43 AM
confucioussae
Sep 19, 2006 08:05 PM
triple_s1x
Feb 27, 2005 11:10 AM
