:: looking for free mods to improve turbo spool up to full boost ::
Old Jul 16, 2003 | 03:02 AM
ID_ten_T's Avatar
Default :: looking for free mods to improve turbo spool up to full boost ::
setup is a stock bore gsr with 10:1 je pistons and t3/60-1. so i was wondering if there are any free/cheap mods that i can do to decrease spool time. i searched the archive and found a boost controller and 3" dp and exhaust. is there anything else i can do? thanks.
Old Jul 16, 2003 | 05:34 AM
Overblown-Teg's Avatar
Default Re: :: looking for free mods to improve turbo spool up to full boost :: (ID_ten_T)
Where is it spooling now? Say in third or fourth gear? Full 3" exhaust is the best thing I can think of. Nitrous would help. Reducing intake pipes as much as possible and running the smalles possible. What ar is your turbine?
Old Jul 16, 2003 | 06:44 AM
RGAZ's Avatar
New User
You can retard the timing and bump up the fuel. The extra hot charge will improve spool.
Also reduce exhaust back pressure as much as possible. High flow cat helps.
Make sure you have no exhaust leaks before the turbo.
Randy
Old Jul 16, 2003 | 08:19 AM
kpt4321's Avatar
Adding fuel wil cause the EGT's do decrease, which is the opposite of what you want. However, within the realm of usable A/F ratios, changing the fuel flow has such a small effect on EGT that I wouldn't even bother.
Retarding the timing will make more of a difference, but it will also decrease power.
Basicially, you want to make your exhaust and intake as free-flowing as possible, and you want to make sure you are using a bost control setup that des not let the WG see a signal until you are in boost (ball-and-spring MBC, most EBC's.)
Old Jul 17, 2003 | 01:50 PM
ID_ten_T's Avatar
Default Re: (kpt4321)
so here's what i get
- n2o
- reduce charge piping
- retard timing (can someone explain this one to me?)
- open dp
- boost controller
anything else? thanks in advance.
Old Jul 17, 2003 | 02:20 PM
RuthlessEF-9's Avatar
i would do everything you listed except retard the timing.. I wasn't to fond about doing this
Old Jul 17, 2003 | 03:14 PM
PureTeg420's Avatar
Default Re: (ID_ten_T)
a properly designed manifold would help quite a bit also. If you have the money, full-race gets my vote.
Old Jul 17, 2003 | 03:16 PM
DLB1994's Avatar
Default Re: (PureTeg420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">a properly designed manifold would help quite a bit also. If you have the money, full-race gets my vote.</TD></TR></TABLE>
Old Jul 17, 2003 | 03:22 PM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">Adding fuel wil cause the EGT's do decrease, which is the opposite of what you want. However, within the realm of usable A/F ratios, changing the fuel flow has such a small effect on EGT that I wouldn't even bother.
Basicially, you want to make your exhaust and intake as free-flowing as possible, and you want to make sure you are using a bost control setup that des not let the WG see a signal until you are in boost (ball-and-spring MBC, most EBC's.)</TD></TR></TABLE>
You only barely kind of right, sir. Retarding the timing AND adding fuel will cause much more to keep burning while it is exiting the combustion chamber, making for even higher egt's.
In addition, running more lean or more rich from stoichiometric (14.7:1) will increase egt's, so it's an illusion that running more lean ONLY will cause EGT's to rise. In reality going either way will raise them.
If you make/buy a manual boost controller make sure it has a small bleed port (like a hair's width in diameter), otherwise it will maintain boost in that portion of the line when you shift, making the turbo take longer to spool in between shifts.
Old Jul 18, 2003 | 01:37 PM
94gsr4dr's Avatar
Default Re: (ion_four)
What are the specs on the 60-1? When do you start makin boost? And when does it hit full boost?
oh and my solution is bigger DP and nitrous
Old Jul 18, 2003 | 01:57 PM
mos's Avatar
mos
Default Re: (94gsr4dr)
Setup your exhuast like that cheesey froggie guy. Hit a switch, and you got instant open down pipe.
Old Jul 18, 2003 | 02:50 PM
boosted92's Avatar
Default Re: (mos)
If you're talking about lag when you're launching, a 2-step will fix that quickly.
Old Jul 18, 2003 | 03:54 PM
Mr Hammond's Avatar
a/k/a Jomo
Full Race mani and a GT series turbo. Oh wait you said free or cheap. Sorry man not a DSM or really a factory turbo'd car for that matter, it's gonna take a little time and $. Basically what everyone said is correct. Get your intake and exhaust set-up as free flowing as possible. I wouldn't do the retard timing thing IMHO.
jdm_rb20
Jul 27, 2013 06:09 PM
rickturboteg
Aug 27, 2006 09:23 AM
mrx
Feb 5, 2004 09:05 AM
V8 BAIT
Feb 7, 2003 05:06 AM
GZERO
Dec 25, 2002 11:10 PM
