quick coilover question
Old Jul 15, 2003 | 08:32 PM
SD_EM1's Avatar
Default quick coilover question
i am planning on changing my suspension to ground controls and i have a friend that has them say his setting for each coilover are different, but his car is even all around. my question is when i do install the coilovers, and i change the settings to get my car to the desired height, will it be normal to have the coilover settings different on all 4 corners of the car? thanks
Old Jul 15, 2003 | 08:45 PM
Mr. Choi's Avatar
New User
Default Re: quick coilover question (One Slow Civic)
all 4 shouldnt be different all the way around, you can have either the front L/R the same or rear L/R at a same height. comparing front to rear can be differerent.
i have pics if you want them. email me
Old Jul 16, 2003 | 04:36 AM
John's Avatar
New User
It's possible that his height settings will all be a little different if he's corner-weighted the car. If it's just the dampening settings, then the front two are usually the same and the rear two are usually the same.
Old Jul 16, 2003 | 08:54 AM
thirdvector's Avatar
Default Re: quick coilover question (DunReit)
He is right. Corner weighting would put them at slightly different levels without much or any visual difference.
Old Jul 16, 2003 | 10:08 AM
SD_EM1's Avatar
cool, thanks. so, is it normal for my friend to have his settings like this: his rear left spring is slightly shorter than his rear right?
Old Jul 16, 2003 | 12:01 PM
John's Avatar
New User
One spring is shorter on one side than the other? Or do you mean the spring perch setting is higher?
Old Jul 16, 2003 | 04:40 PM
SD_EM1's Avatar
woops, sorry about that. yeah i meant the perch. thanks
Old Jul 16, 2003 | 04:52 PM
GSpeedR's Avatar
Hondas do not have equal weight distribution L/R or F/R, so under static load, each spring should compress a little bit differently than another.
Old Jul 16, 2003 | 04:56 PM
Deluzional's Avatar
Default Re: quick coilover question (GSpeedR)
I dont know about your friend, but the ONLY time I had 4 different settings was when me and my friend installed the GC on my car. I immediately got an alignment a couple days after, and had all 4 settings leveled off.
redlinexd
Apr 2, 2011 12:01 PM
silentkillz1
Suspension & Brakes
11
Mar 7, 2009 04:56 AM
dynamitespy
Suspension & Brakes
Jun 16, 2006 08:14 PM
Full Race A6
Jul 30, 2004 07:58 AM
DiPPeD iN miLk Ej CoUpE
Mar 27, 2003 06:04 PM
