WTF... code 16-- fuel injector after hitting vtec 2nd gear redling 3.5
Old Jul 15, 2003 | 07:57 PM
bossman032's Avatar
Default WTF... code 16-- fuel injector after hitting vtec 2nd gear redling 3.5
THis stupid goes comes on once in a while.
Today I go fill up GAS for 5 bucks and hit vtec when exiting gas station it worked all the way..
Again when coming on home hit vtec again second gear car hit rev limiter at 3.5 and suddenly code 16 turned on what can be the problem the FUEL filter or what..?
Old Jul 15, 2003 | 07:59 PM
bossman032's Avatar
Default Re: WTF... code 16-- fuel injector after hitting vtec 2nd gear redling 3.5 (bossman032)
Ohh yea after the code I reset the ECU the code went away hit vtec couple of times the code didn't come back yet
soo I am wondering what can cause the Problem I am using 91 fuel!!!
Old Jul 15, 2003 | 08:20 PM
91civicEX's Avatar
could be a clogged injector. next time it happens listen to the injectors with a screwdriver. put the tip to the injector and the butt to your ear. they should all be clicking.
Old Jul 15, 2003 | 08:36 PM
bossman032's Avatar
Default Re: (91civicLX)
thanks for the tip bro!!!
Old Jul 15, 2003 | 10:57 PM
bossman032's Avatar
Default Re: (bossman032)
anyone else have this probelm...?
Old Jul 16, 2003 | 01:56 PM
civickiller's Avatar
im getting a code 16 on my b18a
Old Jul 16, 2003 | 09:40 PM
bossman032's Avatar
Default Re: (civickiller)
code went away again ****!!!
ohh well vtec works I guess
Old Jul 16, 2003 | 10:32 PM
DohcVtecCrx's Avatar
check the wiring..only time I ever had a code 16 the plug was not on all the way. The ecu sends out voltage to the injectors and then after going through the resister box it goes back to the ecu, so it knows if it is pulsing or not. When there is a break in the cycle the voltage does not get back to the ecu..so it goes to limp mode...safety setings..
Old Jul 16, 2003 | 10:37 PM
Malgerus's Avatar
Default Re: (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">check the wiring..only time I ever had a code 16 the plug was not on all the way. The ecu sends out voltage to the injectors and then after going through the resister box it goes back to the ecu, so it knows if it is pulsing or not. When there is a break in the cycle the voltage does not get back to the ecu..so it goes to limp mode...safety setings..</TD></TR></TABLE>
Good info, thanks. Do you happen to know how OBD-I/II Injectors work then?
Old Jul 16, 2003 | 10:47 PM
Default Re: (Mr. S)
well they do not let alot of voltage back to the ecu like the obd-0 style does, that is why you need to add the resistor box to the wires, so it resists some of the voltage going back to the ecu
bossman032
Dec 16, 2011 11:13 AM
TheCheeseWedge
Jun 3, 2007 10:48 PM
turboxsi
Jun 18, 2004 10:24 AM
BoostedH23a1
Jul 6, 2003 12:13 AM
bossman032
Jun 30, 2003 04:30 PM
