B18A in 91 DX Civic no spark????
Old Jul 15, 2003 | 06:06 PM
CRXBart's Avatar
Default B18A in 91 DX Civic no spark????
Ok, I installed a B18A in a friends car for him. It was allready converted to MPFI, it had a ZC in it. The car has fuel but no spark. One of the wires in the two pin plug at the distributor has power when the Ignition is on. No other wires at the distributor show power, weather it is cranking ignition is on or what not. The distributor gets hot after cranking. Yet no spark is put out. I know the distributor is good because we put it on a LS teg we just bought and it runs fine with it. I know it must be a wiring issue and am getting quite frustrated with the situation. All the plugs are tight and shoudn't be a problem. The only thing tat even brings questions to my mind is a strane sensor on the rear of the motor. It has two wires and a green plug. It can be seen here : http://www.c-speedracing.com/h...n.jpg
Thanks in advance any insight would be greatly appreciated. I'm running out of things to check.
808DA
Mar 26, 2009 05:24 PM
saltyblue
Mar 17, 2005 08:35 AM
integra93
Jan 5, 2004 10:46 AM
CRXBart
Jul 16, 2003 05:00 AM
