Is Vortech coming out with a SC for 94+GSR?
Old Aug 1, 2001 | 11:42 AM
VaporTrail's Avatar
New User
Default Re: Is Vortech coming out with a SC for 94+GSR? (puffy)
forced induction is forced induction when it comes to safety. It doesn't matter how you add the air, what matters is how you add the fuel and ignition.
[Modified by VaporTrail, 3:44 PM 8/1/2001]
Old Aug 1, 2001 | 02:58 PM
JSpecwest's Avatar
New User
Default Re: Is Vortech coming out with a SC for 94+GSR? (VaporTrail)
I called VORTECH and they said their GSR kit is coming out anytime within the next couple of months. In about 3-4 months after the GSR kit comes out, a Type R kit will be available.
Old Aug 1, 2001 | 03:05 PM
dustin's Avatar
I see no real reason why the Vortech Si kit could not be slightly modified to work with a GSR, the setup is almost exactly the same except for the placement of the intake manifold etc. If there is a big difference, please enlighten me
I personally do not think the centrifugal chargers are all that great of an idea; you make half the boost at 4k rpm as you do at 8k rpm! Not a great plan in my opinion.
Either way, boost is boost to an engine as VaporTrail says. JRSC is no more reliable than a turbo setup @ 6psi. changing the boost with a turbo setup is just more tempting, and you must be more meticulous with installation. Once installed properly, reliablity should be entirely equal.
Dustin
Old Aug 1, 2001 | 04:10 PM
dbman96's Avatar
New User
Default Re: Is Vortech coming out with a SC for 94+GSR? (dustin)
I don't think there's a way in the world the vortech could be considered "safer" than a turbo. It is identical except for the way the compressor wheel is powered, so that it actually builds boost slower than a turbo, which is usually peoples' biggest complaint about turbos... I just don't see the logic in spending more for a setup that gives you much less room for increasing power in the future. Oh yeah, and the speeds involved in the gearboxes used to spin that compressor up to speed just make me CRINGE.
Tarzan
May 18, 2006 05:20 PM
HatchedGTI
Jan 9, 2006 11:08 PM
k20em2
Jul 21, 2003 02:52 PM
suprchrg95
Aug 25, 2002 08:57 PM
TeamTooQuick
Feb 18, 2002 12:44 PM
