Car won't boost over 5psi and i have a 9psi spring
Old Jul 15, 2003 | 09:07 AM
u2civic1's Avatar
Default Car won't boost over 5psi and i have a 9psi spring
i have a tial WG with a green spring and it won't boost past 5psi
i have the WG hooked up to the manifold vacuum
Old Jul 15, 2003 | 09:42 AM
Spudddy's Avatar
check for leaks/cracks in the turbo manifold and/or not sealed connections between block and manifold, manifold and turbo and manifold and wastegate
Old Jul 15, 2003 | 10:58 AM
JimmyT89's Avatar
Default Re: (Spudddy)
make sure ur pipes are leaking boost
Old Jul 15, 2003 | 01:33 PM
u2civic1's Avatar
Default Re: (JimmyT89)
if i hook up the wg to the manifold the leaks in the pipes shouldn't really matter rite
Old Jul 15, 2003 | 10:13 PM
u2civic1's Avatar
Default Re: (u2civic1)
found out the problem i was using a nos regulater T tap
BeArDy
Welding / Fabrication
Aug 26, 2011 01:52 PM
delslow1975
May 23, 2010 03:44 PM
007EG
Nov 15, 2007 03:55 AM
Accel Junky
Jan 25, 2004 07:50 PM
tony1
Sep 22, 2003 10:46 AM
