installing shocks/spings
Old Jul 15, 2003 | 05:22 AM
type Gendy's Avatar
Default installing shocks/spings
Does anybody know of a good site that gives a how-to of installing shocks/springs on a crx? I have never done it before, and wanna try to tackle it tonight after work, and i just dont wanna mess it up.....
Old Jul 15, 2003 | 07:02 AM
REDBARON's Avatar
Default Re: installing shocks/spings (sick hatchem)
The search button is your friend. I found this.
https://honda-tech.com/zerothread?id=224395
Old Jul 15, 2003 | 09:47 AM
Cryptopsy's Avatar
Be prepared for a LONG night.....Rusted/seized bolts. Make sure you have an impact wrench or the job will be hell. Pick up some locktight. Check your brake pads....may want to do them while you are at it.
Fighting with seized bolts will be the biggest problem.
Old Jul 15, 2003 | 11:55 AM
Davep's Avatar
Make sure you have another car to drive because you will need it. You will probably have at least one bolt that won't come out. Try using a torch to heat them up and see if that helps. Sometimes that will do the trick, if not they are frozen in the bushing and that’s where the second car comes in handy. You will need to cut out the bolt, press out the bushing and need a new bushing and bolt.
Old Jul 15, 2003 | 07:19 PM
type Gendy's Avatar
I couldn't find much of anything useful searching, but thanks for that post....
I got the front ones on, took me a while but was pretty easy....gonna try the rears tomororw....
Tim2179
Suspension & Brakes
Sep 5, 2010 07:46 PM
bopbop93030
Dec 2, 2008 07:23 AM
Frickr
10
Aug 23, 2008 05:10 PM
futurefastguy
16
Jun 7, 2005 03:53 PM
Carp
Apr 3, 2002 01:13 PM
