Tried Search, No Luck...Pwr windows??
Old Jul 15, 2003 | 02:26 AM
Eibach95Civic's Avatar
Community Builder
Default Tried Search, No Luck...Pwr windows??
i have EX power windows and power locks for my 95 lx, is it hard to install? and if so is there a wiring diagram on how to do it??
Old Jul 17, 2003 | 07:15 AM
Community Builder
Default Re: Tried Search, No Luck...Pwr windows?? (Eibach95Civic)
come on, i know their is a way, but i just dont know how....someone knows
Old Jul 17, 2003 | 08:23 AM
DXturbo's Avatar
its pretty easy... im doing it right now... it just depends what you have... let me know what you have and i can help you....
Old Jul 17, 2003 | 08:30 AM
Community Builder
Default Re: Tried Search, No Luck...Pwr windows?? (DXturbo)
what i have...hhahaha...i have a whole 95 ex coupe sittin in my back yard...trust me i have everything
Old Jul 17, 2003 | 08:44 AM
DXturbo's Avatar
ok...well pretty much take out everything from the door... and take out the harness in the door and the harness that goes through the fender. you can either unplug the harness from the fuse box or you can just cut the wires. if you un plug it then its pretty much plug and play... but that means you would have to change out the whole dash harness casue its all one big harness and that means you will need to take out the dash and thats not fun. anyways, cut the wired and wire it up that way.. all you need to do mis power up the driver side and then after that extend the wires to the passenger side.
the black wire grounds everything... so ground that
white/green - power windows
ill post the rest of the wires when i get home.
Old Jul 17, 2003 | 08:49 AM
Community Builder
ok so i will run those wires to my fuse box where they should be on a ex?? or sum **** like that...hmm, doesnt sound to hard...i'll keep you informed, sounds like you know what your talking about....thanx
nickelz34
Oct 5, 2013 05:47 PM
SILENTJ95835
Oct 17, 2008 06:02 AM
qp
Nov 11, 2006 11:58 PM
flatblk
Nov 4, 2006 08:54 PM
scottybh
Mar 12, 2006 07:29 PM
