Tried Search, No Luck...Pwr windows??
i have EX power windows and power locks for my 95 lx, is it hard to install? and if so is there a wiring diagram on how to do it??
Re: Tried Search, No Luck...Pwr windows?? (Eibach95Civic)
its pretty easy... im doing it right now... it just depends what you have... let me know what you have and i can help you....
ok...well pretty much take out everything from the door... and take out the harness in the door and the harness that goes through the fender. you can either unplug the harness from the fuse box or you can just cut the wires. if you un plug it then its pretty much plug and play... but that means you would have to change out the whole dash harness casue its all one big harness and that means you will need to take out the dash and thats not fun. anyways, cut the wired and wire it up that way.. all you need to do mis power up the driver side and then after that extend the wires to the passenger side.
the black wire grounds everything... so ground that
white/green - power windows
ill post the rest of the wires when i get home.
Re: Tried Search, No Luck...Pwr windows?? (DXturbo)
ok so i will run those wires to my fuse box where they should be on a ex?? or sum **** like that...hmm, doesnt sound to hard...i'll keep you informed, sounds like you know what your talking about....thanx
nickelz34
10-05-2013 05:47 PM
put ex coupe doors with power windows want to make them work in my dx do i need harness from the doo
flatblk
11-04-2006 08:54 PM
