power window conversion
Old 03-06-2006, 08:45 AM
scottybh's Avatar
Default power window conversion
hi all, i'm new and i need some major help. i just spent the last 3 hours trying to wire in some power windows and door locks for my 95 civic coupe dx. i cant figure out where the heck all these darn wires go and where they plug into. the main wiring harness on the drivers side, where does it plug into? is a dx pre-wired for power options (plug-n-play) or do i need wires to go to the fuse box and/or battery? i only have the wires that are in the doors, nothing that goes past there. PLEASE HELP ME!!!!
Old 03-06-2006, 09:05 AM
Relic1's Avatar
you need the floor harness from an EX for it to be plug and play.
you'll need to run the wires to the under dash fuse box, ground and two to the passenger's door.
I did my own harness when I added power windows to my VX. Post up what wire colors you have to work with and I'll step you through what needs to be done.
Old 03-06-2006, 11:44 AM
scottybh's Avatar
Default Re: (Relic1)
on the wire colors, do you mean the power window and door locks or from my car's harness it self....
also, i called a local junk yard and they said i would have to re-wire the whole car with a new main harness and a new fuse box, is that true? sounds expensive, lol....
Old 03-06-2006, 02:41 PM
Relic1's Avatar
if you're doing it all yourself it's not too bad.
if you can give the locks seperate than the window wires I can get what ever you need to connect everything.
Old 03-07-2006, 05:41 AM
scottybh's Avatar
ok, kinda new at givin wire colors but here goes...
window motors
SR3L-blue with red dots (dots are about every inch on all these)
red with blue stripe
black
red with yellow stripe
SR3R-blue with red stripe and silver dots
blue with white stripe
Main Harness out of Drivers side
-blue with green stripe and silver dots (bigger)
blue with green stripe and silver dots (smaller)
blue with black stripe and silver dots
white with yellow stripe and double dots
gray, black stripe, dots
**white, green stripe, double dots
blue, yellow stripe, dots
yellow, white stripe, dbl dots
blue, black stripe, dbl dots
green, white stripe, dbl dots
black, dots
black, dots
black, dots
**black, dots
**green, white stripe, dbl dots
**green, red stripe, dbl dots
**yellow, red stripe, dbl dots
blue, white stripe, dbl dots
**white, red stripe, dbl dots
ok, thats all i saw....i just found out i have no wires for the passenger side door except for the wires coming out of the window and lock motors themselves...guess im gonna have to get those....also, as best as i could tell, the wires with the stars next to them are coming out of the door lock control box.....thank you for all your help, let me know if you need any other info.
Old 03-07-2006, 08:11 PM
Relic1's Avatar
Default Re: (scottybh)
first off great job recording what colors the wires are, everything matched perfectly to what the manual says. Which made it really easy for me to find.
just a FYI, the dots are not important.
stripe is indicated by a / then the color of the stripe. red/blue is red with a blue stripe.
locks are easy, just like in the manual.
**white/green - power from fuse box (12V at all times, 30A fuse)
**black - power lock switch 2
**green/white - power lock switch 1
**green/red - power lock switch 3
**yellow/red - power lock motor output2 (driver's and passenger's)
blue/white - **??? door lock **** input into door lock control box
**white/red - power lock motor output1 (driver's and passenger's)
blue - driver's window pulser signal to motor
red/blue - motor1 output of driver's switch
black - ground
red/yellow - motor2 output of driver's switch
blue/red - motor1 output of passenger's switch
blue/white - motor2 ouput of passenger's switch
blue/green(bigger) - ????
blue/green(smaller) - driver's switch signal to passenger's window switch
blue/black - passenger's window power from power window relay
white/yellow - driver's window power from power window relay
gray/black - ????
blue/yellow - driver's switch signal to passenger's window switch
yellow/white - ????
green/white - ????
black - ground
black - ground
black - ground
green/red - ????
yellow/red - ????
white/red - ????
I thought I had all the wires figured out in the 2door power windows. Since it's not covered in the Helm manual I rtried to peice things together using the 4-door pages.
But since I did mysetup with aftermarket window motors and OEM switches I only had to figure out how things were used, not the colors.
Maybe between the two of us we can step you through this and at the same time document this for future people doing this.
this is what I put together based on what I know about the switches for the power windows.
http://www.b18c5eg.com/2d-3d%2....html
I appologize if this seems overwhelming and confusing.
If you could take the plugs that you have (bottom of the page C605 and C629) and list the colors in each position I'll update the page with the right colors. Once we have that much I can tell you in simple terms how to hook everything up.
Old 03-09-2006, 05:52 PM
scottybh's Avatar
hey relic, sorry its been a few days, been so busy....anyways, this may seem dumb but im not sure which plugs i need to look at. i have a few that look like both of those in the pic. just let me know exactly which one and ill get you all the colors again. thanks again for all your help.
Old 03-09-2006, 05:53 PM
scottybh's Avatar
also, now that we know what each wire is, is there anyway to tell where exactly where i need to wire them to? thanks again!
Old 03-12-2006, 07:29 PM
scottybh's Avatar
lol....beginning to wonder if it woulda been easier to just buy an ex.....hahaha....i hate tryin to do things on my own when i have no idea how to do them.....well, i tried to wire them but they're still not workin....do you have any idea where to wire these things to?
crazyLemons4.20
12
05-29-2013 06:43 PM
BiG_DeE
05-24-2008 11:54 PM
egg_baLLa
06-01-2006 02:52 PM
Filliam H. Muffman
12
09-24-2003 07:59 PM
Eibach95Civic
07-17-2003 08:49 AM
Quick Reply: power window conversion
