5g civic ex swap
I was lookin at some engines and I am just learning about cars starting to get into it a bit more. I am lookin to swap somthing with my stock civic engine I was thinking the b18c just because I have a hook up to get a very good price on it. but anyone got any suggestions
What you should do is use the search function for any info that you are looking for first. And for your question, since it is dealing with swaping a motor, you should search in the Hybrid forum for your answer.
Most of the time, you can find an answer just by searching.
But for example, if you wanted to know how to put a B18c into your 95 EX, then just search under "B18c swap" or something to that extent and there will be many posts about the topic.
Also, when you search, look under both recent and archived topics because a lot of stuff was covered two or three years ago and might answer your very question.
And if you can't find it, don't hesitate to ask, but be specific about what you need to know.
Hope that helps, and welcome to H-T
