gsr swap into my hatch
Old Jul 14, 2003 | 10:01 PM
civicbeater97's Avatar
Default gsr swap into my hatch
94 gsr into my eg all wiring is hooked up and gettin spark and fuel but still not starting...ne ideas for me guys???????????/
Old Jul 14, 2003 | 10:27 PM
salbaje's Avatar
Default Re: gsr swap into my hatch (civicbeater97)
starter bad??? keep cranking it so that fuel can get in the system
Old Jul 15, 2003 | 12:04 AM
NiiS's Avatar
I`m assuming you did the mandatory maintenance, IE water pump, T-belt and such. you should have checked to se if the crank pulley was@ TDC while you were in there. If not, now would be a good time to do so
Old Jul 15, 2003 | 05:28 AM
4DRPIMPIN's Avatar
Check your timing first then go from there..
Old Jul 15, 2003 | 07:49 AM
NiiS's Avatar
Default Re: (4DRPIMPIN)
If the crank pulley is`nt set at TDC to begin with, how is he going to accurately check his timing? One tooth can mean the difference between fire and no fire...
Old Jul 15, 2003 | 08:23 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (sinister)
Check your grounds, check your fuses, check your timing belt, check all the accessory pullies and check your main relay.
Then get back to us.
Randal Melkus
Jul 3, 2014 09:48 AM
civctegncrx
Mar 1, 2009 11:21 AM
AE_Racer
24
Sep 13, 2007 02:53 PM
CTRwannaB
13
Mar 29, 2004 08:11 AM
Hybrid CRX
Jan 10, 2004 06:43 PM
