bench bleading
Old Jul 14, 2003 | 09:24 PM
S13 slide's Avatar
Default bench bleading
how do you bench blead the brake master cyl.? my old master cyl. went bad and i had an extra one laying around. i put it in and the pedal still doesnt have much pressure. when the cars off and i press the brakes it gets rock hard. so im thinking since i didnt bench bleed it that i need to. thanks btw its on a 91 civic si
Old Jul 14, 2003 | 10:33 PM
salbaje's Avatar
Default Re: bench bleading (S13 slide)
take off the lines that go into the master cylinder. then put in a line in place and route it inside the master cylinder then push the pedal in and out. do it a couple of times. after doing that put lines back and bleed the brake lines. hopefully this makes sense
Old Jul 14, 2003 | 11:04 PM
S13 slide's Avatar
Default Re: bench bleading (salbaje)
hey thanks for the reply, but uh how does one get a line to run into the master cyl? do i have to find some lines from a junkyard and cut em off? or any homedepot comtraptions people have used?
also theres a bolt between the two lines, whats that for? thanks
civicexowner
Jun 18, 2009 03:07 PM
ZippyZivic
Mar 24, 2009 07:58 PM
fatfurious2
Mar 14, 2007 02:55 PM
dxhatch92
Jan 16, 2007 08:13 PM
