"Max boost" with 11:1 cr with stock sleeves????
Old Jul 14, 2003 | 05:36 PM
NXAccordTO4B's Avatar
Default "Max boost" with 11:1 cr with stock sleeves????
Ok guys im about finish my lastest block. I need to know how much boost that my stock sleeves can handle.
setup:
f22b1 with 11:1 cr
SS valves
crower rod
wisco pistons
and all ur fuel and ignition stuff.
im currently in search for a stand alone.
Old Jul 14, 2003 | 06:31 PM
boosted hybrid's Avatar
Default Re: "Max boost" with 11:1 cr with stock sleeves???? (NXAccordTO4B)
They are capable of handling at least 400whp. Compression doesnt matter how much boost you can run on your stock sleeves, its in the tuning that matters. Reduce the cylinder pressures and you'll save the sleeves alot of deformation and shearing forces.
Old Jul 15, 2003 | 12:28 PM
Default Re: "Max boost" with 11:1 cr with stock sleeves???? (boosted hybrid)
what do u mean by reducing the cylinder pressure? do u mean lower CR?
thanks
fusion645
Dec 31, 2009 08:40 PM
turbo_b16_ex
Nov 9, 2005 07:44 PM
B18 CYA
Apr 7, 2004 03:43 PM
NXAccordTO4B
Jul 19, 2003 08:27 PM
trillo
May 29, 2002 10:43 AM
