Recommendations for Transmission Oil
Old Jul 14, 2003 | 12:27 PM
panykus's Avatar
Default Recommendations for Transmission Oil
Do you guys have any recommendations for a 2000 USDM Type R Tranny Transmission Oil? I believe my manual says SP grade 10W-30 or 10W-40. The regular stuff I bought at checker was a valvoline GL grade 75W-90. What is the difference in the GL standard vs. SP? Also, I believe the 75W-90 will not provide the viscosity I need when engine is warming up, correct? Someone recommended Redline... Where can I buy it and for how much? I'm open to any other brand recommedations too... Thanks...
Old Jul 14, 2003 | 12:30 PM
976's Avatar
976
New User
Default Re: Recommendations for Transmission Oil (panykus)
I only recommend Honda MTF!
Old Jul 14, 2003 | 12:33 PM
94si94cx's Avatar
Default Re: Recommendations for Transmission Oil (976)
Make a trip to your local Honda/Acura dealership and pickup some Honda MTF!
Old Jul 14, 2003 | 12:34 PM
Chris y0!'s Avatar
I only recommend Redline MTL!
Old Jul 14, 2003 | 12:35 PM
SpoonFedHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">I only recommend Honda MTF!</TD></TR></TABLE>
Old Jul 14, 2003 | 12:50 PM
panykus's Avatar
I forgot to mention I will primarily be road racing the car
Old Jul 14, 2003 | 12:51 PM
Chris y0!'s Avatar
Default Re: (panykus)
redline
Old Jul 14, 2003 | 12:55 PM
00MRSi's Avatar
Default Re: (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! &raquo;</TD></TR><TR><TD CLASS="quote">redline </TD></TR></TABLE>
Damn, Chris no need to get upset.
I think Honda MTF or Redline will do fine. If you have the extra cash to spend then try the Redline..
Old Jul 14, 2003 | 01:17 PM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panykus &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to mention I will primarily be road racing the car</TD></TR></TABLE>
HKS FF/Gear
Old Jul 14, 2003 | 01:22 PM
Clutch101's Avatar
Royal Purple Synchromax!
Old Jul 14, 2003 | 01:26 PM
976's Avatar
976
New User
Hey **** ****. We heard you the first time.
Would you like me to explain why I prefer Honda MTF, because it does not allow deteroration of sycros like Redline...
Old Jul 14, 2003 | 01:28 PM
ejprimo's Avatar
Default Re: (976)
any transmission fluid thats GL-4 spec.
Old Jul 14, 2003 | 01:51 PM
b16supertuner's Avatar
Default Re: (ejprimo)
GM Synchromesh OWNS ALL
Old Jul 14, 2003 | 01:57 PM
AzG35's Avatar
Old Jul 14, 2003 | 01:58 PM
panykus's Avatar
Hi guys, I didn't mean to cause any stress... I did check some prices - $7.95 per quart for Redline MTL From Carroll Shelby Racing in Phoenix, Arizona, and $3.99 per quart for the Honda MTF from Bell Honda. I would need around 3-4 quarts for a complete drain. As long as the Honda MTF will stand up to the rigours of road racing, I will probably go with the Honda MTF. I did read up on the Redline MTL properties on the redlineoil.com website and must say it sounded quite impressive, but do I really need it? What do you guys think?
Old Jul 14, 2003 | 02:18 PM
panykus's Avatar
Someone just mentioned that I might need something special for a tranny with a Limited Slip Differential as those generate more heat.... Anyone using any particular tranny oil in their tranny with LSD? I know people with Kaaz LSDs that use Kaaz gear oil...
Old Jul 14, 2003 | 02:20 PM
Chris y0!'s Avatar
talk to this guy:
https://honda-tech.com/zero...98180
he'll help you out on what tranny oil to use.
Old Jul 14, 2003 | 02:22 PM
TravisEK's Avatar
Old Jul 14, 2003 | 02:48 PM
careawholelot's Avatar
Default Re: Recommendations for Transmission Oil (TravisEK)
redline
Old Jul 14, 2003 | 02:55 PM
NonovUrbizniz's Avatar
Loved
Default Re: Recommendations for Transmission Oil (careawholelot)
I use redline but just to clarify to the poster (because everyone tries to be all l33t by not really explaining anything they just hint at stuff...)
there is debate as to whether or not redline tranny oil causes deterioration of the transmission bearings and synchros....
HOWEVER... I have to say that personally I was using Redline MTL... and it's great... my tranny is on it's way out anyway so I don't much care if it causes long term damage... but it DEFINATELY made the tranny run MUCH smoother than it ever did before (except when new for me @ 60k mi.). and a LOT of the whurring associated with bad bearings went away however it's NOT gone...
So I say for safety's sake if nothing else stay away from redline...
If anyone has any better or clearer information, I for one would LOVE to hear...
Old Jul 14, 2003 | 02:56 PM
Kamin's Avatar
Default Re: Recommendations for Transmission Oil (NonovUrbizniz)
honda MTF rules.
Old Jul 14, 2003 | 03:58 PM
panykus's Avatar
Thank you to everyone for their inputs. I posted this question on the ITR forum as well, since I though that with a LSD I minght need special Tranny Oil. Most of the replies said that they were happy with Honda MTF, and one guy even uses it for road racing. So for now I guess I'll stick with Honda MTF and see how that works. Thanks again for your help...
Old Jul 14, 2003 | 04:12 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Recommendations for Transmission Oil (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! &raquo;</TD></TR><TR><TD CLASS="quote">I only recommend Redline MTL!</TD></TR></TABLE>
yep
Old Jul 14, 2003 | 04:34 PM
deepnite's Avatar
Default Re: Recommendations for Transmission Oil (TURSpoonEK)
redline has 2 GL-4 fluids..the MTL and MT-90..if use 2 qts of MTL for easier shifting in high and low temps. and top it off with MT-90 for better protection against tranny wear
Old Jul 14, 2003 | 05:43 PM
drunknbass's Avatar
ive always used mtf or 10/30 in the past and my tranny syncros always go bad..so my next tranny im using royal purple 75-90 . ifigure thethicker gear oil will prolongthelife of the tranny.. but with lsd i wouldnt use anything other than gl4.. basically synthetic gear oil with limitedslip additive..
mofo951
Jun 18, 2008 10:25 AM
panykus
Feb 8, 2005 07:14 PM
JDMCRX
Apr 29, 2003 05:46 PM
raene
Nov 23, 2002 01:11 AM
Ek4 B16A2
Sep 3, 2002 09:09 AM
