best twin disk clutch to go with
Old Jul 14, 2003 | 12:01 PM
buck02's Avatar
Default best twin disk clutch to go with
im looking at getting the best twin disk clutch for my h22 civic the 2 i am in decicive about are the clutch masters or the tiltom ceramic not the tilton carbon carbon there way out my price range but there for a high horsepower street car thanks for the helpfull input
Old Jul 14, 2003 | 12:30 PM
tegasaurus's Avatar
Default Re: best twin disk clutch to go with (h22civic2)
tilton ceramic is a great choice. I hear nothing but praise from those things.
Tilton clutches are proved with the higher horsepower guys (600+). If you don't plan on surprassing the 500 hp mark, a 6 puck act would be a very good clutch.
-ryan
Old Aug 11, 2004 | 09:00 PM
buck02's Avatar
Default Re: best twin disk clutch to go with (tegasaurus)
what about the exedy clutch twin disk ceramatallic i here there awsome and pedal feel is awsome
Old Aug 11, 2004 | 09:01 PM
Bspec18's Avatar
Exedy
Old Aug 12, 2004 | 05:41 AM
buck02's Avatar
Default Re: best twin disk clutch to go with (Bspec18)
that is was i was leaning toward i wonder if u use the tilton slave cylinder kit on the exedy it will help i here there soft allready with stock slave cylinder
Old Aug 12, 2004 | 06:30 AM
BROOD's Avatar
Default Re: best twin disk clutch to go with (buck02)
Does anyone know for a fact if the Tilton TOB will work with another manuf's twin disk clutch (exedy, CM, etc)? I know it will not work with a single disk clutch even if it is a single tilton.
I'm went with a Tilton ceramic, just waiting for Stan to get the FW moddified.
Old Aug 12, 2004 | 04:02 PM
buck02's Avatar
Default Re: best twin disk clutch to go with (BROOD)
good poin i wonder if it will help the exedy twin at all and even work with it
Old Aug 12, 2004 | 04:41 PM
Kwuaymaikrup's Avatar
Are you going to daily drive this car? I have the Tilton twin disk and it is a pain in the *** to drive. fter you get going it isn't that bad but be carefull downshifting, this is where you will need to master rev matching. Although I do not have the Tilton TO bearing. The engagement is brutal, it is an on/off clutch, no if's and's or but's about it. I am curious as to what the Competition Clutch twin disk is like. I would like to hear from people that have that one. If the engagement is a little softer and can hold the power I would take that over the Tilton.
-Ryan
Old Aug 12, 2004 | 04:43 PM
buck02's Avatar
Default Re: best twin disk clutch to go with (Kwuaymaikrup)
from what i here the exedy is way softer and can hold it better and i here its a better clutch and yes i plan to use it as a daily driver
Old Aug 15, 2004 | 02:12 PM
buck02's Avatar
does anyone know if the tilton bearing kit will work with the exedy twin disk clutch set up and will be any better that the stock fork type
mrlegoman
Oct 31, 2006 05:30 PM
LSEGHATCH
Jun 30, 2006 08:19 PM
MoBoost2JZ
Sep 12, 2004 12:34 PM
hovic
Aug 15, 2004 02:37 AM
TrickHonda98
12
Jun 14, 2004 08:48 AM
