drive train HELP!!!!!!
Old Jul 14, 2003 | 09:52 AM
delpoop!'s Avatar
Default drive train HELP!!!!!!
im haveing a problem with my car!!!
we can put the car in gear and give it gas while we slowly let off the clutch the car will not move but the rpm and the speedo is rising we can go thru all the gears but car still dosent move im assuming that it is the axles what do all of you think, any help will be appreciated..
thank you.
also the clutch slave seems fine and the clutch is brand new four stage clutch masters. we did have the trannie out becuase the housing cracked so we replaced all the housing and al the neccessary bolts and seems to be mounted fine the throttle bearing dosent wiggle we thought it might be the throttle bearing on the shaft closeset to the clutch but i dont know whats wrong with it.
please help..
Old Jul 14, 2003 | 09:55 AM
delpoop!'s Avatar
Default Re: drive train HELP!!!!!! (delpoop!)
Old Jul 14, 2003 | 10:30 AM
NonovUrbizniz's Avatar
Loved
has it driven at ALL since you put in the clutch?
because that sound a WHOLE LOT like a clutch... maybe something's mis-installed...
Old Jul 14, 2003 | 11:14 AM
delpoop!'s Avatar
Default Re: drive train HELP!!!!!! (NonovUrbizniz)
yeah
it drove
Old Jul 14, 2003 | 11:37 AM
Loved
does it "feel" like the clutch is engaging/dis-engaging... it sounds like the clutch is stuck open... ie not ever making the connection between flywheel and tranny.
Old Jul 14, 2003 | 11:40 AM
Crave's Avatar
Push the clutch in, put the car in 5th, then let out the clutch, you should be able to feel it if it's engaging the transmission or not.
Old Jul 14, 2003 | 05:10 PM
delpoop!'s Avatar
Default Re: (Crave)
when you try to drive the car it goes through all the gears fine but the car doesnt move but when all the mtf has time to circulate throught the tranny it will start pouring out of the tranny about where the paenger side axle goes in to the tranny
Old Jul 14, 2003 | 07:05 PM
Loved
Default Re: (delpoop!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delpoop! &raquo;</TD></TR><TR><TD CLASS="quote">when you try to drive the car it goes through all the gears fine but the car doesnt move but when all the mtf has time to circulate throught the tranny it will start pouring out of the tranny about where the paenger side axle goes in to the tranny</TD></TR></TABLE>
Well...
1st... this isn't you is it?
https://honda-tech.com/zerothread?id=562423
2nd... does it FEEL like it's going into gear from the shifter... IE the shift fork engaging the gear...
3rd... Does the clutch pedal FEEL like it's going in and out normal or is it smoother or harder than normal...
Addressing whay you said about the leak... it sounds like you need an axel seal on that side... however that should have nothing to do with the problem origonally posted...
I need more details if you want me to help... How long did it drive for before it stopped... where there any major sounds or happenings when it stopped? etc etc.
Old Jul 14, 2003 | 07:08 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (NonovUrbizniz)
ok if the speedo is moving, that means the diff is turning. is there metal in the tranny? did the diff come apart?
Old Jul 15, 2003 | 08:38 AM
Blowensi's Avatar
Default Re: (boostedcivicsir)
the diff is fine its pretty new (quaife lsd) well looks like the oil is leaking from the trannie where the axle goes into the diff i dont belive its pushed in all the way cuase when we give it gas it starts to pour out of that area.
Old Jul 15, 2003 | 09:25 AM
Mr. Badwrench
Default Re: (Blowensi)
i think you have a doff problem or a case problem. think about it, if the speedo is working, then the ring gear has to be spinning. i havent seen a quaiffe break yet but i dont think it is impossible. but thats my assumption. i think you need to start looking into the tranny internals.
Old Jul 16, 2003 | 02:37 PM
Blowensi's Avatar
trannies good
the problem is that i belive the passanger axle was not properly put all the way in becuase it was driving fine till we heard a pop now the area where the axle and the diff fits is leaking oil.
Old Jul 16, 2003 | 07:51 PM
Mr. Badwrench
that would cause the diff not to turn either. sorry on that. missed that.
Pl4yb0y
Feb 22, 2013 06:24 PM
got2
Jun 20, 2006 08:49 PM
dazuk
Mar 2, 2006 11:52 AM
Flexer
Apr 16, 2004 07:43 AM
JdmFront619
Oct 28, 2003 12:25 PM
