help!!!!!
Old Jul 14, 2003 | 09:18 AM
delpoop!'s Avatar
Default help!!!!! DRive TRain!!!!
im haveing a problem with my car!!!
we can put the car in gear and give it gas while we slowly let off the clutch the car will not move but the rpm and the speedo is rising we can go thru all the gears but car still dosent move im assuming that it is the axles what do all of you think, any help will be appreciated..
thank you.
also the clutch slave seems fine and the clutch is brand new four stage clutch masters. we did have the trannie out becuase the housing cracked so we replaced all the housing and al the neccessary bolts and seems to be mounted fine the throttle bearing dosent wiggle we thought it might be the throttle bearing on the shaft closeset to the clutch but i dont know whats wrong with it.
please help..
Old Jul 14, 2003 | 09:27 AM
delpoop!'s Avatar
Default Re: help!!!!! DRive TRain!!!! (delpoop!)
bump.
Old Jul 14, 2003 | 11:16 AM
delpoop!'s Avatar
please help!!!!!!!111
Old Jul 14, 2003 | 12:31 PM
RCautoworks's Avatar
Will the car die out if its in gear and you don't give it any gas ?
Old Jul 14, 2003 | 04:51 PM
delpoop!'s Avatar
Default Re: help!!!!! DRive TRain!!!! (90blackcrx)
no it does not die
Old Jul 14, 2003 | 04:56 PM
Sounds to me like its not even in gear, did you guys install everything correctly ?
Old Jul 14, 2003 | 05:08 PM
b16supertuner's Avatar
are you sure you put that THROWOUT bearing in correctly?
Old Jul 14, 2003 | 07:17 PM
Turbogixxer's Avatar
I think that is an axle(s) too. double check to see if they are all the way in before you start tear things apart.
Old Jul 14, 2003 | 08:12 PM
NonovUrbizniz's Avatar
Loved
SERIOUSLY HOW MANY THREADS ARE YOU GOING TO START ON THIS...
Old Jul 15, 2003 | 08:36 AM
Blowensi's Avatar
Default Re: help!!!!! DRive TRain!!!! (turbogixxer)
its leakin from the diff where the axle connects to the diff so i think its not all the way in.
Old Jul 15, 2003 | 08:52 AM
Default Re: help!!!!! DRive TRain!!!! (Blowensi)
Yep, sounds like it is not in all the way.
Old Jul 16, 2003 | 02:38 PM
Blowensi's Avatar
yeah well thanks for your response turbogixxer youve helped me alot. thanks again to all that have helped me..
antivic
Jul 13, 2006 02:13 PM
sencarus
Jul 4, 2006 12:47 PM
user 98292739
Feb 2, 2005 01:42 PM
95civicracer
Jul 30, 2003 09:08 PM
delpoop!
12
Jul 16, 2003 07:51 PM
