2000 accord, can't get rotor retaining screw out
Old Jul 14, 2003 | 07:58 AM
00accord's Avatar
Default 2000 accord, can't get rotor retaining screw out
Ok, I have the wheel off, and I see the two #3 phillips screws. So far I've broken off a bit in one and partially stripped the other. For now I just put it back together, but I think my rotors are warped so I need to do this before they get too bad to resurface and have to be replaced.
Anybody have any suggestions for how to get these off? Also, how about a good place to get a cheap dial indicator to check the rotors?
Thanks
Old Jul 14, 2003 | 08:02 AM
urbanlegend21's Avatar
New User
Default Re: 2000 accord, can't get rotor retaining screw out (00accord)
you need a hammer impact screwdriver
it is a screwdriver that turns when hit by a hammer, kinda like an impact but a hard jolt all at once
Old Jul 14, 2003 | 08:54 AM
2003 VTEC's Avatar
Default Re: 2000 accord, can't get rotor retaining screw out (urbanlegend21)
Just drill them out. The screws are very soft metal. I woldn't bother replacing the suckers either. Totally worthless junk, they do nothing.
Old Jul 14, 2003 | 09:18 AM
FREAKquency04's Avatar
did you try using an impact screw driver??? use one of those to get that screw out
Old Jul 14, 2003 | 09:40 AM
00accord's Avatar
Default Re: 2000 accord, can't get rotor retaining screw out (AcCorDH22ARaCeR)
Wow, that was fast, I'm gonna go get one of those impact drivers tonight and give it a shot, thanks for the advice guys...I'll let you know how it goes.
Old Jul 14, 2003 | 12:13 PM
020's Avatar
020
that's no moon
Default Re: 2000 accord, can't get rotor retaining screw out (2003 VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2003 VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Just drill them out. The screws are very soft metal. I woldn't bother replacing the suckers either. Totally worthless junk, they do nothing. </TD></TR></TABLE>
they must do something..
Old Jul 14, 2003 | 01:53 PM
Hannibal's Avatar
Default Re: 2000 accord, can't get rotor retaining screw out (leibchen)
The screws are placed in the rotors on the assembly line, so the rotors don't fall off as it travels through the line.
Old Jul 14, 2003 | 04:08 PM
2003 VTEC's Avatar
Default Re: 2000 accord, can't get rotor retaining screw out (Hannibal)
And once the calipers are installed, those rotors ain't going anywhere. But actually, the wheel holds the rotor on, mostly. And, most cars don't have those dumb screws. They usually rust up solid in a matter of months. I wish they didn't use those!
SlowPokeEg
Jan 12, 2014 10:31 PM
Capitan Mark
Oct 12, 2009 03:31 PM
flowlrak
Oct 27, 2004 07:37 PM
1998hondaaccord
Mar 14, 2004 05:57 AM
wbrown
May 15, 2003 04:50 AM
