actual HP gain of going from 2.5" to 3"???? How much?
Old Jul 14, 2003 | 07:09 AM
glagola1's Avatar
Default actual HP gain of going from 2.5" to 3"???? How much?
I'm trying to decide if it is worth the cost of a 3" exhaust system. I currently have a 2.5" thermal R+D and I was thinking of going to a 3" thermal. I'm running 1 bar of boost from the Apex'i kit on a B18B1.
Does anybody have any first hand experience of going from 2.25 or 2.5 to a 3"? What kind of numbers did it produce and was the in-car volume raised significantly?
Thanks
Old Jul 14, 2003 | 07:14 AM
TurboLude97's Avatar
Default Re: actual HP gain of going from 2.5" to 3"???? How much? (glagola1)
i went from a 2.5" to a 3" exhaust but i also took the cat out and gained 40 hp.
Old Jul 14, 2003 | 07:22 AM
glagola1's Avatar
Default Re: actual HP gain of going from 2.5" to 3"???? How much? (TurboLude97)
That sounds GRRRR-REAT!!!
I'm running a 2.5" test pipe too but...
My power really drops in the high revs. I'm hoping that back pressure is partially to blame.
Old Jul 14, 2003 | 08:36 AM
TurbodCX's Avatar
Its not the exhaust that makes it drop in the higher revs, it is the small turbo.
You need a bigger turbo for the higher RPM's
3" is probally just going to make it worse.
Brian
Old Jul 14, 2003 | 09:35 AM
glagola1's Avatar
Default Re: actual HP gain of going from 2.5" to 3"???? How much? (TurbodCX)
Yeah, the IHI is pretty small but I don't see how going to a 3" could make things worse. See, my torque peak is in the same spot as a stock N/A ls so I'm thinking the torque drop has something to do with the nature of the stock motor as well.
Old Jul 14, 2003 | 09:38 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX &raquo;</TD></TR><TR><TD CLASS="quote">Its not the exhaust that makes it drop in the higher revs, it is the small turbo.
Brian</TD></TR></TABLE>
agreed!
but I personally would get a bigger downpipe and have it taper down to 2.5 full exhust.
**heres a though:..... keep your current exhust and just get a custom downpipe with an e-cutout
vg7z
Jun 2, 2006 07:01 PM
93dx--hatch
Apr 17, 2003 07:03 PM
gsr sol
Feb 9, 2003 06:19 PM
b18cTurbo
Feb 26, 2002 06:41 PM
sleepy
Sep 5, 2001 06:36 PM
