:: ignition recommendations :: digital 6 and blaster hvc vs 6a & blaster ss vs stock ::
Old Jul 14, 2003 | 05:18 AM
ID_ten_T's Avatar
Default :: ignition recommendations :: digital 6 and blaster hvc vs 6a & blaster ss vs stock ::
i was wondering what everyone recommends for turbo ignition setups. in searching the archives i found these setups. which one would be the best for 350whp? i am guessing that the digital 6 setup is a higher end setup, so at what point would you switch from the 6a to the digital 6? thanks.
msd digital 6 and blaster hvc coil
https://honda-tech.com/zerothread?id=561806
msd 6a and ss blaster coil
https://honda-tech.com/zerothread?id=492278
and of course stock
Old Jul 14, 2003 | 05:38 AM
turbologist's Avatar
Default Re: :: ignition recommendations :: digital 6 and blaster hvc vs 6a & blaster ss vs stock :: (ID_ten_
I heard quite a few bad things about the Digital 6....As far as dependibilty and it being prone to burning out...Im sure someone has some expereince here with that...The regular 6 is like ye old faithful.....thats something you can count on and it will more than support your 350+ whp..
Old Jul 14, 2003 | 09:18 AM
CRXRageD's Avatar
Don't get an SS coil. The ignition boxes are fine but stay away from the SS coil, they don't always fire correctly. And they are prone to malfunctioning.
Old Jul 14, 2003 | 10:49 AM
VaporTrail's Avatar
New User
you dont need it. I and many others have proven all you need is a good functioning STOCK ignition system. Stock right down to the plug wires.
Old Jul 14, 2003 | 11:37 AM
FULLTHROTTLE's Avatar
<--- MSd 6BTM with HVC coil. I havent had a single problem in years with this setup. Street and strip. Also as a test to its strength it made over 780 HP on a Mopar I tune.
Old Jul 21, 2003 | 10:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXRageD &raquo;</TD></TR><TR><TD CLASS="quote">Don't get an SS coil. The ignition boxes are fine but stay away from the SS coil, they don't always fire correctly. And they are prone to malfunctioning.</TD></TR></TABLE>
See I had the SS coil for a year and a half now it works fine....I ran an 11.2 with just that coild and the rest of the ignition was bone stock...
I just think that MSD has a serious problem with quality control...Its not that one product is bad and another is good...Its more like what users have had a good experience with and what they have not...
hksitr
Nov 1, 2009 01:53 PM
jdm inc
Apr 5, 2009 09:32 AM
crxsiperf
Feb 18, 2005 07:01 AM
agent_noman
Feb 12, 2003 02:40 PM
