cel 16, car won't start
Old Jul 14, 2003 | 04:39 AM
Artful Dodger's Avatar
Default cel 16, car won't start
I was backing out of my driveway last night and I got distracted and stalled the car. After that it wouldn't start again. I'm now getting cel 16 which is the fuel system. Fuel pump primes and the engine turns over. You guys have any ideas? where do I start. thanks
Old Jul 14, 2003 | 05:12 AM
Neptune's Avatar
Default Re: cel 16, car won't start (Artful Dodger)
(16) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-95 88-95 n/a 88-91 93-95 95 88-95
Fuel Injector System
defective circuit or unplugged / defective fuel injector
I would check out the injectors see if you see any visable damage to them. Check all your connections too.
Old Jul 14, 2003 | 06:08 AM
thomas551's Avatar
i had that code 16 when i bought my eg for $2500 thats why i got it for that much.....So when i got home the chiltons said injectors, The problem with mine was #3and#4 the positive wire was cut and thats why it was running off of 2 cycl.....Easy fix for a eg in good condition for $2500....So make for u check all the wiring to the Fuel injectors.......
Old Jul 14, 2003 | 10:15 PM
Default Re: (thomas551)
woke up this morning and the car started w/ no code. I'm really confused...
Old Jul 16, 2003 | 08:05 PM
Spoonin's Avatar
Default Re: (Artful Dodger)
I am having a similar problem, except it will start and stall right out (did it 5 times in a row at the gas station last night)but, it will start fine the first time, especially if it is cold outside.
Holla back if you find out, the problem. Everyone tells me it might be the main fuel relay or the ignitor.
Old Jul 16, 2003 | 09:23 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Artful Dodger &raquo;</TD></TR><TR><TD CLASS="quote">woke up this morning and the car started w/ no code. I'm really confused...</TD></TR></TABLE>
lol, ya cars can be wierd that way. i had 3 cels on for like the past 4 months, every time i reset the battery they'd come back within a day or two. now for some reason it fixed itself or something, because it's been a week and no cel. yay. i'm a happy man.
Old Jul 16, 2003 | 09:30 PM
Infinity_Racer's Avatar
Default Re: (civicdxtyper)
it prolly got mad cus you weren't paying attention and stalled
but i would def. check your injector wires to see if they're ok...wiggle them around and reset the ecu even though the CEL doesnt come on anymore..
Modified by Infinity_Racer at 3:15 AM 7/17/2003
Old Jul 16, 2003 | 09:48 PM
all stock's Avatar
Default Re: (Infinity_Racer)
most likely - electronic. check ur connections.
Old Jul 16, 2003 | 10:46 PM
krazyDOHC's Avatar
Default Re: (all stock)
could be electrical...but add some fuel injection cleaner to be safe...it may be clogged
Old Jul 17, 2003 | 07:46 PM
Spoonin's Avatar
Default Re: (krazySOHC)
http://www.markl.f9.co.uk/howt...y.htm
Check out the above site (just the first part, don't try to fix the relay, it won't be worth your time). I had the exact same problems with my car. It would not start when it was hot, play with the key for a little while or let it sit and it would start. Sometimes after a short run (like getting gas) the car won't start after it has been turned off. Started and died on me after a few seconds like, 5 times in a row. Got a new relay today and I haven't had a problem starting the car now.
curvy95honda
Apr 15, 2011 09:34 AM
dividedas1
Jun 23, 2009 01:46 PM
annointed
Nov 28, 2004 06:30 PM
stRtypR25
May 30, 2003 05:29 PM
legendboy
Apr 22, 2002 01:35 PM
