5th gear is popping out.......?
Old Jul 13, 2003 | 11:28 PM
hmongdude's Avatar
Default 5th gear is popping out.......?
When i'm on the freeway after awhile my 5th gear pops out of place.... does anyone know why this is happening..............?
HELP...........
Old Jul 13, 2003 | 11:42 PM
97hb's Avatar
Default Re: 5th gear is popping out.......? (hmongdude)
Probably a bent shifter fork.
Old Jul 14, 2003 | 01:14 AM
Malgerus's Avatar
Default Re: 5th gear is popping out.......? (97hb)
Before you do replace that, check and replace your shift linkage bushings.
Old Jul 14, 2003 | 03:44 AM
advanracing62's Avatar
Default Re: 5th gear is popping out.......? (Mr. S)
could be low on fluid, you may have a small leak, the synchro could be going....
Old Jul 14, 2003 | 05:15 AM
REDBARON's Avatar
Default Re: 5th gear is popping out.......? (advanracing62)
This was happening to my brother once. I checked the tranny fluid, and it was really low. I drained, and re-filled it with Honda MTF, and it hasn't happened again.
Old Jul 14, 2003 | 07:58 AM
torr's Avatar
Default Re: 5th gear is popping out.......? (REDBARON)
does it happen when you let go of the gas. if so it may be a bad synchro. if not it may just be something simple like everyone else said. tranny fluid etc.
Old Jul 14, 2003 | 09:40 AM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">could be low on fluid, you may have a small leak, the synchro could be going.... </TD></TR></TABLE>
I agree, I'm willing to bet ya that you are just low on fluid... Drain it, dump a couple quarts of MTF in there and see how it goes... If that's not it, then consider opening up the tranny... Good Luck and let us know how it goes... Latez
Old Jul 14, 2003 | 10:46 AM
hmongdude's Avatar
Default Re: 5th gear is popping out.......? (Kataku2K3)
Thanks for the feedback guys...... I'll check up on it and let you guys know what happend..... I just changed fluids not too long ago so i'll recheck it incase I didn't put enough... Good looking out guys...... lates
Old Jul 14, 2003 | 01:17 PM
hatch4raceb16's Avatar
ya, i had the same problem, my fluids were low and it popped out, put in tranny fluid and it went away.
py389itr
Feb 28, 2007 04:41 PM
civic_speed99
Jan 20, 2005 06:39 PM
RiCE On IcE 2
Jul 26, 2004 04:32 PM
BrownGSR
Oct 13, 2003 02:01 PM
TrueDC2
Oct 3, 2003 12:13 PM
