car starts but radomly dies?
i just bought an accord. it'll start fine but it'll die radomly...without any notice that its going to die.
has anyone had this problem before?
i mean it doesn't studder or anything like that.
any help would be kool
o by the way its a 94 lx 2dr
i'm pretty sure its not over heating or anything like that....it can happen while the car is being driven or while its at idle.
i was thinking maybe fuel pump?
Yeah, my car was doing the same thing...I'm on the highway then all of a sudden **** cuts off out the blue. I found out it was the ignition switch...try that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRwannaB »</TD></TR><TR><TD CLASS="quote">how do i check to see if its the ignition switch?
Unplug the wiring from the back, get an ohm-meter to measure continuity, and a Helm manual to tell you what terminals are supposed to be connected to which others at each position of the switch. As you're checking, wiggle the key or the switch because wiggling it is NOT supposed to make the connection all flaky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iongerz »</TD></TR><TR><TD CLASS="quote">is an ignition switch same as an ignition module?
The ignition switch is the electrical switch behind the lock cylinder where you put the key.
The ignition module is in the distributor. Lots of people call it an ignitor.
</TD></TR></TABLE>Unplug the wiring from the back, get an ohm-meter to measure continuity, and a Helm manual to tell you what terminals are supposed to be connected to which others at each position of the switch. As you're checking, wiggle the key or the switch because wiggling it is NOT supposed to make the connection all flaky.
Guest
Posts: n/a
I also have the same problem. I have a 94 Lx coupe too and my car dies on me quite often. This doesnt usually happen on the FWY though, but when i come to a complete stop, the rpm's drop to 0 then dies on me. The car doesnt shake or studder prior to the dying.
My team-mates and I have checked my spark plugs and they seem to be in good condition.
We've also changed the rotor. After i put the new rotor in, it seemed to be fine. Later that night i took my car to the canyons and it seemed to run great.
However, I also have a problem with a loss of power during 2-5 rpm. My car seems to lag in second alot and occasionally 3, 4, 5. For ex: I was on the FWY (in traffic) in third, when i saw an opening in the next lane, i downshifted to second and punched it, yet my car felt like **** and lagged through 2-5 rpm and then the power finally kicked in.
This problem also occured once in the canyons. (which was a lil scary)
I was thinking that maybe its the fuel. I have a B&M FPR. Do you think there isnt enough fuel pressure or fuel being pushed through?
Any help would be great guys. Thanks!
Hey I was curious if anyone could email me with a step by step on how to replace the main relay....I have a 1990 honda accord lx. And if anyone would like to sell me one instead of getting raped at honda, let me know. Uncendo1@hotmail.com thanks again and keep tuning
mine dies when I first start it up sometimes randomly. I'm thinking my idle control valve is screwed up because it idles low most of the time, and right now, it surges at idle sometimes too (like a vacuum leak)....but then steadies out, and then does it again a few seconds later, very odd.
Mine seems to be doing the same thing. After it warms up it runs fine. Any ideas? I have a 92 B16a with 450cc injectors, vafc, and Revhard kit. Help would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr »</TD></TR><TR><TD CLASS="quote">Hey I was curious if anyone could email me with a step by step on how to replace the main relay....I have a 1990 honda accord lx. And if anyone would like to sell me one instead of getting raped at honda, let me know. Uncendo1@hotmail.com thanks again and keep tuning
heres a link to a step by step diy...
http://autorepair.about.com/li...1.htm
</TD></TR></TABLE>heres a link to a step by step diy...
Jstone1983
Apr 14, 2011 07:23 PM
